- 55
- 122 小时
- 2013-5-27
- 50
- 288921
- 58
- 55 点
- 55 ¥
- 2011-2-4
Features:120 watts x 2 min. RMS, both channels driven into 8 ohms from 20Hz to 20kHz with no more than 0.02% THD, 120 Watts x 2 min. RMS, driven into 4 ohms, with no more than 0.07% THD. 4 ohm Rated (FTC)
120 watts x 7 min. (2 Front, 1 Center, 2 Rear speakers) RMS, into 8 ohms, 1kHz, 0.2/0.7% THD
DVD Multichannel Audio Compatible (6 channel inputs and 5 separate amps) for connection to existing and future multichannel sources such as DVD Audio
RF/IR illuminated LCD multi-brand A/V-CATV-DBS remote control for operation from anywhere in your home. Learning Capability
Dynamic Super A amplifier
C.C. Converter (all channels) provides better resolution ,enhanced ambience, and greater depth by eliminating distortion known as "jitter" and "ripple"
1-bit P.E.M. D.D. Converter greatly enhances signal to noise ratio and dynamic range (192kHz/24-bit, 7.1ch)
Dolby Digital/DTS decoders built-in for theater quality surround from digital sources
Digital Acoustics Processor (DAP), with 12 modes DSP
3 Band Parametric EQ for all 7.1 channels
3D-PHONIC Virtual Surround Sound creates dramatic home theater sound with just two front speakers
Multi-room/Multi-source capability allows you to play two different Audio or Video sources in two different rooms at the same time with both composite and S-video outputs.(for example, play a CD in the bedroom while someone listens to a cassette tape in the kitchen)
Text COMPU LINK will transmit text data carried by media like CD-Text and MD to display on your receiver and a television
Line Direct for pure audio sources like CD
AV COMPU LINK provides simple one touch operation between your JVC audio and video components. For example, pop a pre-recorded VHS tape into the VCR and it will automatically power up your receiver and your television and then turn them each to the proper inputs.
Enhanced COMPU LINK Control System
On Screen Display simplifies control by allowing you to choose options from your television screen to operate your receiver
Line level Sub Out
Balance, One-Touch Operation, Velocity-Sensitive Rotary Encoder Volume Control
HD(35mHz) component outputs for chrystal clear video switching with no signal loss: 1 In/2 Out
9 Audio Inputs
4 Audio Outputs
5 Composite Video Inputs (1 on Front Panel)
TV Sound
Front A/V Input with S-Video (Gold Plated) for the convenience of hooking up any A/V source quickly and easily such as a camcorder or video game
7.1-Channel Pre-outputs for added flexibility in creating a high end A/V system
Sub Room Pre-Amp Outputs allows you to enjoy 5.1 surround in the main room and 2 channel stereo in the sub room with the addition of an outboard amp
1 Assignable Coaxial Digtial Input that you can designate to any digital source
5 S-Video inputs (1 on Front Panel)
3 S-Video outputs
3 Composite Video outputs
2 Main Speaker Terminals
Surround Back Speaker Outputs
Center Speaker Terminals
2 Surround Sound Speaker Terminals
15 AM and 30 FM station memory
2 Year parts and labor warranty
Weight: 49 lbs
Width: 17 9/16"
Height: 7"
Depth: 18 3/4"
Multi-Way Banana Type binding posts for easy speaker connections (Main1/Main2[sub room]/Center/Surround/Surround Back)
High-Rigidity Z-Chassis
Dolby Pro Logic in Full Digital Processing
4 Optical Digital Inputs
1 Optical Digital Output |
