看看著名的ZAPH对D6.8的评价,也认为D6.8与Morel或Dynaudio的同类单元有类似的内置磁铁,但是有更好的驱动以及更好的谐波失真表现,如果要用这种内置磁铁类型的低音,宁可选D6.8而不是Morel或Dynaudio,不过D6.8有12个螺丝孔,用的螺丝过多了. ZAPH也是HIVI的枪手
This Hi-Vi poly cone driver has a 3" voice coil with an inset magnet similar to Morel and Dynaudio woofers. The difference is that the Hi-Vi has a superior motor and outperforms them in the harmonic distortion department. If I were going to use this style of inset magnet woofer, I would choose the Hi-Vi over Morel or Dynaudio. I hope you like screwing, because the Hi-Vi has 12 mounting holes which is a bit excessive. Tested December 2006.
