- 203
- 539 小时
- 2017-8-28
- 50
- 131446
- 232
- 203 点
- 221 ¥
- 2009-9-12
我刚进了对低音单元有单元参数但是全市英文的,小弟英文是个文盲,上网翻译又看不明白,想请那位师傅帮忙解释下这参数。
Electrical Data
Nominal Impedance
Zn
ohm
DC Resistance
Re
5.5
ohm
Voice Coil Inductance
Le
0.2
mH
TS Parameters
Resonance Frequency
fs
Hz
Mechanical Q factor
QMS
1.7
Electrical Q factor
QES
0.26
Total Q factor
Qts
0.22
Force Factor
Bl
7.8
Tm
Mechanical Resistance
Rms
1.7
Kg/s
Moving Mass
Mms
g
Effective Piston Area
sd
cm^2
Equivalent Volume
Vas
49
ltrs
Sensitivity
2.83V/1m
89
dB
Power Handling
100h RMS noise test
IEC
W
Voice Coil and Magnet Parameters
Voice Coil Diameter
mm
Linear Excursion +/-
6.5
mm
Max mech. excursion +/-
mm
Drawing Dimensions
Outside Diameter
OD
166
mm
Magnet Diameter
MD
121
mm
Cutout Diameter
CD
144
mm
Interior Depth
ID
75
mm
Hole Diameter
HD
3.5
mm
Screw Circle Diameter
SD
163
mm
想做个书架音箱,但是看不懂它的参数,
这是高音,没有高音的参数。 |
