[其他] 中国的接触器在巴西能用吗
[复制链接] 查看: 3464|回复: 8
646 点
237 ¥
发表于 2010-7-21 20:41 | 显示全部楼层
167 点
162 ¥
发表于 2010-7-21 21:02 | 显示全部楼层
lucky
1098 点
1075 ¥
发表于 2010-7-21 21:10 | 显示全部楼层
百度一下
646 点
237 ¥
 楼主| 发表于 2010-7-21 21:18 | 显示全部楼层
166 点
186 ¥
发表于 2010-7-21 23:20 | 显示全部楼层
巴西的电压好像是120
166 点
186 ¥
发表于 2010-7-21 23:22 | 显示全部楼层
巴西电流的电压是110伏特、60赫兹。如果您到巴西旅游带不能用110伏特、在60赫兹的器,比需要个电压converter。
There are three main types of voltage converter. Resistor-network converters will usually be advertised as supporting something like 50-1600 Watts. They are light-weight and support high-wattage electrical appliances like hair dryers and irons. However, they can only be used for short periods of time and are not ideal for digital devices.
Transformers will have a much lower maximum Watt rating, usually 50 or 100. Transformers can often be used continuously and provide better electricity for low wattage appliances like battery chargers, radios, laptop computers, cameras, mp3 players and camcorders. However, they are heavy because they contain large iron rods and lots of copper wire.
Some companies sell combination converters that include both a resistor network and a transformer in the same package. This kind of converter will usually come with a switch that switches between the two modes. If you absolutely need both types of converter, then this is the type to buy.
巴西插头Adapters和插座形状
在巴西的插座常常能用2 types of plug
Flat blade plug
Two round pins
If your appliances plug has a different shape, you may need a plug adapter.
Depending on how much you plan to travel in the future, it may be worthwhile to get a combination voltage converter and plug adapter.
166 点
186 ¥
发表于 2010-7-21 23:26 | 显示全部楼层
1629 点
1407 ¥
发表于 2010-7-22 08:02 | 显示全部楼层
百度说是三相220 单相127。不知道中国有没有这种的接触器买得到
zjh37891 发表于 2010-7-21 21:18
你到温州柳市低压电器城里全世界的电压的都有。
司令
14 点
55 ¥
发表于 2010-7-22 08:20 | 显示全部楼层
欧洲的能用
