A superb Home DJ Monitoring system with USB stereo amplifier and a pair of high quality 3-way speakers giving a clear, wide range frequency response with excellent bass. Designed to play MP3 files directly from USB storage devices.
Product features:
120W max/channel power amplifier
USB and MP3 inputs on the front panel and RCA audio (L&R) on the rear panel
Front located controls for MP3 playback when in USB mode
Supports MP3 file format only
Blue backlight VU meter
Speaker connection via 4mm gold plated terminal posts
Each speaker enclosure contains dual 6.5" woofers and 1" dome tweeter
High quality black grainy PVC coated cabinets with silver/grey detachable grilles, c/w 2 x 3m speaker cables
Fan cooled
Supplied with 3.5mm stereo jack - 2 RCA phono audio lead with gold plated contacts for optimum signal transfer
Specifications:
Power supply 230Vac, 50Hz
Power rms 60W/channel
Load Impedance 8 ohms
Frequency response:Amplifier 10Hz - 30kHz
Frequency response:Speaker 40Hz - 20kHz
SPL @ 1W/1m 89dB
THD <0.7%
Input sensitivity 218mV, 1k ohms
S/N ratio >80dB
Dimensions:Amplifier 375 x 95 x 220mm
Dimensions:Speaker 200 x 225 x 540mm
Weight:Amplifier 5.1kg
Weight:Speaker 13kg (pair)
