1341 点
728 ¥
发表于 2006-8-20 23:08 | 显示全部楼层
<p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">&nbsp;&nbsp;&nbsp; <font size="4">虽然以前也装过不少小玩意但全都是成品线路板,真正意义上的洞洞板制作几乎不高兴做,原因是太花费时间,而且布局和走线也是一个问题。因为我个人认为在相同的走线情况下洞洞版的走线是用铜丝等“立体”金属导线,其所产生的干扰要远远大于铜箔板制作的线路板。所以有时候看到较好的电路也只能作罢。</font></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';"><font size="4"></font></span>&nbsp;</p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><font size="4"><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">&nbsp;&nbsp;&nbsp; 前一段时间看到论坛上都在谈论</span><span lang="EN-US"><font face="Times New Roman">MBL</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">的前级,而且线路也极其干练简单,所以每当空余时就弄了一个</span><span lang="EN-US"><font face="Times New Roman">MBL</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">的主放大部分,并增大了对负载的驱动能力。</span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">制作材料都是以前多余下来的,机壳是车载</span><span lang="EN-US"><font face="Times New Roman">-12V to ~220V</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">变换器的,前后挡板都是散热和插座洞所以就改用了快</span><span lang="EN-US"><font face="Times New Roman">2mm</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">厚的中密度板“立体裁剪”就成了下面的样子。</span></font></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><font size="4"><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';"></span></font>&nbsp;</p><p>
我所谓的MBL前级初步形成
我所谓的MBL前级初步形成
<br/>
我所谓的MBL前级初步形成
我所谓的MBL前级初步形成
</p><p><font size="5">有空先画些线路图,绝对有好处。</font></p><p><br/>&nbsp;</p><p>
我所谓的MBL前级初步形成
我所谓的MBL前级初步形成
<br/>
我所谓的MBL前级初步形成
我所谓的MBL前级初步形成
</p><p><font size="5">为了焊接方便有几处先做造型在上板焊接</font><br/></p>
我所谓的MBL前级初步形成
我所谓的MBL前级初步形成
<br/>
我所谓的MBL前级初步形成
我所谓的MBL前级初步形成
<br/><font size="5">上面的只作了3/4</font>
我所谓的MBL前级初步形成
我所谓的MBL前级初步形成
<br/>
我所谓的MBL前级初步形成
我所谓的MBL前级初步形成
<br/>
我所谓的MBL前级初步形成
我所谓的MBL前级初步形成
<br/>
我所谓的MBL前级初步形成
我所谓的MBL前级初步形成
<br/>
参与人数 1经验 +20 威望 +2 HD币 +50 贡献值 +2 收起 理由
wzy728 + 20 + 2 + 50 + 2
1341 点
728 ¥
 楼主| 发表于 2006-8-21 14:18 | 显示全部楼层
<div class="quote"><b>以下是引用<i>口水龙王</i>在2006-8-20 23:57:00的发言:</b><br/>不错!!!那个金封用的是什么?</div><p>是BB公司的产地UK,型号给JS刮掉了,感觉上应该不会是什么好片子,但是购买时因为听感不错,所以玩一下喽。</p><p>在运用过程中发现此运放在“缓冲”和“主放大”线路中的声音表现明显不一致。</p><p>在反复比较了一些运放后,我的观点是此运放转换速率不会超过5V/us。</p><p></p>
85
认证会员 当前离线
傻人不眨眼
1889 点
1830 ¥
认证会员
发表于 2006-8-21 08:56 | 显示全部楼层
<p>&nbsp;&nbsp;&nbsp; 从做工就可看出,楼主是个一丝不苟的人,动手能力很强,diy的乐趣体现的很好。不知音质能有mbl的</p><p>几成,看来还没彻底完工,金封的运方是放大吗?是什么型号?</p>
4023 点
2287 ¥
发表于 2006-8-21 08:32 | 显示全部楼层
不错.建议板主加精.[em03]
9137 点
2729 ¥
论坛贵宾
发表于 2006-8-21 00:56 | 显示全部楼层
电位器比mbl的还强啊
1711 点
783 ¥
发表于 2006-8-21 00:22 | 显示全部楼层
漂亮!!
1106 点
380 ¥
发表于 2006-8-20 23:57 | 显示全部楼层
不错!!!那个金封用的是什么?
1341 点
728 ¥
 楼主| 发表于 2006-8-20 23:17 | 显示全部楼层
<p><font size="4">累了,RCA座不高兴装了。</font></p><p><font size="4">面板原来的是木纹帖,感觉不好,弄了张广告贴纸裁切后弄上去,还没有上胶,等有空再说。</font></p><p><font size="4">外接供电就差机壳了。</font></p><br/>
1341 点
728 ¥
 楼主| 发表于 2006-8-20 23:12 | 显示全部楼层
<p><font size="6">继续</font></p><p>&nbsp;</p><p>&nbsp;</p>
我所谓的MBL前级初步形成
我所谓的MBL前级初步形成
<br/>
我所谓的MBL前级初步形成
我所谓的MBL前级初步形成
<br/><font size="5">上面的是接地点</font>
我所谓的MBL前级初步形成
我所谓的MBL前级初步形成
<br/>
我所谓的MBL前级初步形成
我所谓的MBL前级初步形成
<br/>
我所谓的MBL前级初步形成
我所谓的MBL前级初步形成
<br/>
1341 点
728 ¥
 楼主| 发表于 2006-8-22 22:07 | 显示全部楼层
<div class="quote"><b>以下是引用<i>wode</i>在2006-8-22 16:42:00的发言:</b><br/><p>因为我个人认为在相同的走线情况下洞洞版的走线是用铜丝等“立体”金属导线,其所产生的干扰要远远大于铜箔板制作的线路板。</p><p></p><p>这个观点是不是立马改变了?呵呵.</p></div><p>首先:这个观点我是永远不会变的,只不过凭人的耳朵是听不到的而已。</p><p>其次:“洞洞版的走线其所产生的干扰要远远大于铜箔板制作的线路板”这并不是我不用洞洞版DIY的原因。</p><p>我想在仪器的帮助下有些杂波和干扰应该看得很清楚的。</p>
128
887 点
215 ¥
发表于 2006-8-22 16:42 | 显示全部楼层
1341 点
728 ¥
 楼主| 发表于 2006-8-22 16:18 | 显示全部楼层
<div class="quote"><b>以下是引用<i>weizinou</i>在2006-8-22 9:39:00的发言:</b><br/><p>逛逛兄:</p><p>&nbsp;&nbsp;&nbsp;&nbsp;礼拜天把5534并联继续进行了视听 ,声音没有回音(这在理论上好像不通),声音的厚度比一个好一</p><p>点,声音松弛了一些,高音不紧了,最好的是中音,人声很不错的,有点lp的味道,关键是这种声音听着一</p><p>上午都不会累的,ary兄说他没听出区别的,起码说明声音没有变坏的倾向,你一定要试一试啊,下一步我</p><p>准备用洞洞版搭一个主放大是并联(两个运方有各自的外围元件)的板子,在加上等响电路,我想声音会又是</p><p>另一番感受。</p></div><p></p><p><font size="4">5534并联后有“回音”是你那个《DIY MBL6010 好声的几点经验》的坛子里“yuno”同学讲的,我只是对他的试验结果表示论同。</font></p><p><font size="4">我想有各自回路的两片并联应该问题不大,在各自的输出端最好串一个电阻,这样每块芯片都有自己独立的信号回路,互不干扰。如果你手头上有5532的话那会给你的排版和制作带来方便,至少在电源走线方面带来些益处。我下一步也有这个打算。</font></p><p><font size="4">在上海有一个老烧友大家都叫他“老洪”虽然脚不大好,但DIY的热情却非常的高,居然每声道用8片AD811并联!但出来的声音不在怎么地。我估计他在并联的方面没有做好,最主要的还应在芯片供电方面下些功夫。因为芯片之间的电流回路会通过供电电路发生串扰,何况他用这么多芯片并联,还有这么多芯片并联输出,常规来讲其后应该加一级缓冲比较好。这是我的个人意见希望大家指正。</font></p>
85
认证会员 当前离线
傻人不眨眼
1889 点
1830 ¥
认证会员
发表于 2006-8-22 15:06 | 显示全部楼层
<div class="quote"><b>以下是引用<i>HQ</i>在2006-8-22 13:14:00的发言:</b><br/>虽然绝大多数的仿制者都未曾听过原机的声音,但从网上的原机图片里不知大家又能领略到多少玄机?!<br/><br/><br/></div><p>这的确是个思路啊,我愣是没看出,我会继续看的 ,直到看出为止。如果你有感悟,请告知大家,我就不再看了啊。看的我眼都疼了,呵呵。</p>
需要开板找我:)
1429 点
272 ¥
发表于 2006-8-22 14:09 | 显示全部楼层
<p>不错,希望楼主能给详细图纸。。。。</p>
399
超级版主 当前在线
16987 点
8777 ¥
发表于 2006-8-22 13:14 | 显示全部楼层
317 点
109 ¥
发表于 2006-8-22 11:09 | 显示全部楼层
每颗运放都单独用一组稳压供电,绝对有惊喜!
85
认证会员 当前离线
傻人不眨眼
1889 点
1830 ¥
认证会员
发表于 2006-8-22 09:39 | 显示全部楼层
55
村委书记
2288 点
2328 ¥
发表于 2006-8-21 17:30 | 显示全部楼层
[B]以下是引用[I]逛逛[/I]在2006-8-21 15:56:00的发言:[/B][BR]<p></p><p><font size="4">MBL的机器我没有听过,所以不好评论。在洞洞板布局及设计的时候有一些没考虑周全,最大的遗憾是有一个输出端在安装锣丝后边[em06]。</font></p><p><font size="4">剩下的还需要买一些信号线,我比较中意“古河”,因为比较中性。</font></p><p><font size="5">在安装过程中发现“CMC”牌RCA座有二对是“大新”(仿冒)的。心情不爽啊。有时间上图</font>。</p><p>金封运放是用在主放大部分型号不知道,因为被JS刮掉了。</p><p>说道动手能力自以为还可以,但为了减少不必要的家庭矛盾还是少弄为妙啊,毕竟兴趣不是生活的全部!</p><p>剩下的事我想试试你的5534直接并联的味道,好像蛮诱人的,至少我这样认为,看看到底在音质上有多少变化;驱动能力是不是比我上面做的强。</p><p></p>
[em01][em01][em01][em01][em01][em01][em01][em01][em01] 在家里老是搞小老婆。 [em01][em01][em01]
1341 点
728 ¥
 楼主| 发表于 2006-8-21 15:56 | 显示全部楼层
<div class="quote"><b>以下是引用<i>weizinou</i>在2006-8-21 8:56:00的发言:</b><br/><p>&nbsp;&nbsp;&nbsp; 从做工就可看出,楼主是个一丝不苟的人,动手能力很强,diy的乐趣体现的很好。不知音质能有mbl的</p><p>几成,看来还没彻底完工,金封的运方是放大吗?是什么型号?</p></div><p></p><p><font size="4">MBL的机器我没有听过,所以不好评论。在洞洞板布局及设计的时候有一些没考虑周全,最大的遗憾是有一个输出端在安装锣丝后边[em06]。</font></p><p><font size="4">剩下的还需要买一些信号线,我比较中意“古河”,因为比较中性。</font></p><p><font size="5">在安装过程中发现“CMC”牌RCA座有二对是“大新”(仿冒)的。心情不爽啊。有时间上图</font>。</p><p>金封运放是用在主放大部分型号不知道,因为被JS刮掉了。</p><p>说道动手能力自以为还可以,但为了减少不必要的家庭矛盾还是少弄为妙啊,毕竟兴趣不是生活的全部!</p><p>剩下的事我想试试你的5534直接并联的味道,好像蛮诱人的,至少我这样认为,看看到底在音质上有多少变化;驱动能力是不是比我上面做的强。</p><p></p>
1341 点
728 ¥
 楼主| 发表于 2006-9-8 18:32 | 显示全部楼层
1/4W电阻组成的电桥极烫。
GMT+8, 2026-3-9 18:24 , Processed in 0.200528 second(s), 12 queries , Gzip On, Redis On.
