- 620
- 3937 小时
- 2025-7-18
- 50
- 16538
- 712
- 620 点
- 515 ¥
- 2006-12-28
NAND device: Manufacture ID: 0xec, Chip ID: 0x76 (Samsung K9D1208V0M)
Could not found stored vivi parameters. Use default vivi parameters.
Press Return to start the LINUX/Wince now, any other key for vivi
type "help" for help.
FriendlyARM> help
Usage:
flash [{cmds}] -- Manage Flash memory
cpu [{cmds}] -- Manage cpu clocks
bon [{cmds}] -- Manage the bon file system
reset -- Reset the system
param [eval|show|save [-n]|reset] -- set/get parameter
part [add|del|show|reset] -- Manage MTD partitions
mem [{cmds}] -- Manage Memory
loadyaffs {...} -- Load a yaffs image to Flash
markpart [-bad|-good] [partname1] [partname2] ...
-- mark blocks in a partition(s) as bad or good
eboot -- Run Wince Ethernet Bootloader(eboot)
wince [ram] -- Run Wince from flash or ram
load {...} -- Load a file to RAM/Flash
go <addr> <a0> <a1> <a2> <a3> -- jump to <addr>
dump <addr> <length> -- Display (hex dump) a range of memory.
call <addr> <a0> <a1> <a2> <a3> -- jump_with_return to <addr>
boot [{cmds}] -- Booting linux kernel
help [{cmds}] -- Help about help?
?iendlyARM> reset
VIVI version 0.1.4 (root@vmwarelinux) (gcc version 2.95.3 20010315 (release)) #0
.1.4 Mon May 14 15:46:54 CST 2007
MMU table base address = 0x33DFC000
Succeed memory mapping.
DIVN_UPLL0
MPLLVal [M:7fh,P:2h,S:1h]
CLKDIVN:5h |
