- 64
- 30 小时
- 2011-12-14
- 50
- 148775
- 84
- 64 点
- 64 ¥
- 2009-11-19
特性
10-W/ch into an 4- Load From a 17-V Supply
15-W/ch into an 8- Load From a 28-V Supply
Operates from 10 V to 30 V
Efficient Class-D Operation
Four Selectable, Fixed Gain Settings
Internal Oscillator (No External Components Required)
Single Ended Analog Inputs
Thermal and Short-Circuit Protection with Auto Recovery Feature
20-pin DIP Package
APPLICATIONS
Televisions
说明
The TPA3122D2 is a 15-W (per channel) efficient, Class-D audio power amplifier for driving stereo single ended speakers or mono bridge tied load. The TPA3122D2 can drive stereo speakers as low as 4. The efficiency of the TPA3122D2 eliminates the need for an external heat sink when playing music.
The gain of the amplifier is controlled by two gain select pins. The gain selections are 20, 26, 32, and 36 dB.
有板吗?感兴趣哦 |
