5Y3
[复制链接] 查看: 2671|回复: 2
114 点
-10 ¥
发表于 2006-7-19 10:47 | 显示全部楼层
<p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><font size="3"><span lang="ZH-CN" style="FONT-FAMILY: SimSun; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'; mso-fareast-language: ZH-CN; mso-ansi-language: ES;">请问</span><span lang="ES" style="mso-ansi-language: ES;"><font face="Times New Roman">5AR4 </font></span><span lang="ZH-CN" style="FONT-FAMILY: SimSun; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'; mso-fareast-language: ZH-CN;">和</span><span lang="ES" style="mso-ansi-language: ES;"><font face="Times New Roman">5U4G</font></span><span lang="ZH-CN" style="FONT-FAMILY: SimSun; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'; mso-fareast-language: ZH-CN;">可否直接代替</span><span lang="ES" style="mso-ansi-language: ES;"><font face="Times New Roman">5Y3?<p></p></font></span></font></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><span lang="ES" style="mso-ansi-language: ES;"><p><font face="Times New Roman" size="3">&nbsp;</font></p></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><span lang="ZH-CN" style="FONT-FAMILY: SimSun; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'; mso-fareast-language: ZH-CN; mso-ansi-language: ES;"><font size="3">谢</font></span><span lang="ES" style="mso-ansi-language: ES;"><p></p></span></p>[em01]
114 点
-10 ¥
 楼主| 发表于 2006-7-19 12:02 | 显示全部楼层
<p>明白了,谢谢!</p><p>&nbsp;</p><p>&nbsp;</p>[em07][em07][em07]
292
nostalgia
19692 点
12949 ¥
发表于 2006-7-19 11:46 | 显示全部楼层
<p>5U4G替换5Y3可能会造成变压器灯丝绕组过载,5U4G灯丝电流3A,5Y3灯丝电流2A,变压器灯丝绕组有裕量则替换无问题</p><p>5AR4和5Y3灯丝电流相同,但是为旁热式整流管,输出电压较高</p><p>当变压器次级交流有效电压较高,且滤波电容耐压裕量不足时,5AR4可能会造成电容击穿。当然这种可能性很小,因为5AR4预热时间更长,电源不处于空载状况,电压不会过高,一般是可以替换的</p>
