5672 点
5633 ¥
发表于 2009-12-18 20:51 | 显示全部楼层
Burning Amp
by Nelson Pass
http://www.passdiy.com/pdf/BA2_%20r1.pdf2009年发布的。
贴过几幅图来。
燃烧着的功放的简图
燃烧着的功放的简图
燃烧着的功放的供电电源
燃烧着的功放的供电电源
燃烧着的功放的输出级
燃烧着的功放的输出级
燃烧着的功放的前端
燃烧着的功放的前端
180 点
178 ¥
发表于 2009-12-19 01:48 | 显示全部楼层
沙发
905 点
905 ¥
发表于 2009-12-19 08:27 | 显示全部楼层
726 点
697 ¥
发表于 2009-12-19 10:17 | 显示全部楼层
5001 点
4973 ¥
发表于 2009-12-19 10:40 | 显示全部楼层
后面不是单端输出了?
842 点
773 ¥
发表于 2009-12-19 10:58 | 显示全部楼层
燃烧着的功放
未见火光!!
侠之大者 当前在线
1747 点
1671 ¥
发表于 2009-12-19 11:29 | 显示全部楼层
靓图,温度高,够发烧!
1796 点
1646 ¥
DIY大赛获奖
发表于 2009-12-19 12:28 | 显示全部楼层
这图有意思,有点象1969的场效应管变形版,输出能力比1969大多了。
5672 点
5633 ¥
 楼主| 发表于 2009-12-19 13:31 | 显示全部楼层
5# hifi8
阁下喜欢单端的就链接这里http://www.passdiy.com/pdf/BA1_%20r1.pdf
Burning Amp 1就是单端甲类输出级的。
The noise is 30 uV, the input
impedance is 49 Kohms, and the damping factor is 33.
噪声是30uV,输入阻抗49K,阻尼因子33
Here is the distortion vs output for this stage at 1 Khz into 8 ohms:
Burning Amp 1 单端甲类 输出级
Burning Amp 1 前端
Burning Amp 1 前端
Burning Amp 1 电源
Burning Amp 1 电源
1451 点
1442 ¥
发表于 2009-12-19 18:23 | 显示全部楼层
pass又有新品了,期待啊!
5672 点
5633 ¥
 楼主| 发表于 2009-12-20 11:29 | 显示全部楼层
This front end circuit also includes parts that provide bias voltages to both the positive and
negative halves of the output stage.
这前端电路包括提供正负各一半的偏置电压。
the positive bias network
consisting of R212, R213, R214, Z201, C209, and P202.
正偏压网络由R212, R213, R214, Z201, C209, and P202组成。
The P202 is used to adjust output to 0 volts DC.
P202用于调节中点为0V直流。
the negative half of the output stage formed by R216, R217,
R218, R219, C207 and Q204.
负偏压网络由R216, R217,
R218, R219, C207 and Q204.组成。
R219......try values starting with 47 Kohm or so,
decreasing the resistance for less bias current.
R219......的阻值可以试从47K左右开始,减少阻值则偏流减少。
BA#1前端电路
BA#1前端电路
5672 点
5633 ¥
 楼主| 发表于 2009-12-20 21:14 | 显示全部楼层
The point between R208 and R209 is “bootstrapped” from the output of the amplifier through
C208. In many designs a constant current source would be employed here, but this approach
is not only simpler but provides voltage drive greater than the positive supply voltage so that
the maximum output of the amplifier gets as close to the supply rail voltages as possible.
在R208和R209之间的点是通过C208来自于输出的自举增益的。在很多设计恒流源将会被用于此处,但这里的解决之道不但简单而且提供的电压驱动超过正电源电压因此放大器的最大输出有可能接近电源电压。
刀客戴维
3752 点
3638 ¥
发表于 2009-12-20 22:07 | 显示全部楼层
没看明白
2645 点
2645 ¥
发表于 2009-12-21 12:54 | 显示全部楼层
LZ可否把图整清楚些.看着有些晕,加之对电路陌生.就...呵呵
5672 点
5633 ¥
 楼主| 发表于 2009-12-21 18:05 | 显示全部楼层
14# LAOQIANG
链接这里http://www.passdiy.com/pdf/BA1_%20r1.pdf有很清晰的图的。
这BA#1前端是包括了输出级的正负电压偏置网络,关于电压配置网络在11楼有介绍。
去掉这正负电压偏置网络就很简单了,
输入级是差分对2sj109,也可以用2sj74代替只是性能稍差。
Q202 和 R205构成恒流源提供这差分对的偏流,Q202是N沟道JFET2SK170,Idss约为10mA,如找不到这么大的Idss的管子,也可以并联运用,而且P201提供调节电流的灵活性。
R201=R202,R203=R204,
增益由R203/R201比值决定,如你需要较高的增益,可以调节R201和R202的值。
补偿电容C201和C202。
Q203的偏流约15mA,与之串联的R208和R209是3W电阻。
C204和R215滤除输出高于200KHz频率。
C203是10Uf的聚丙烯电容输出电容。
264 点
269 ¥
发表于 2009-12-21 19:32 | 显示全部楼层
单看中文题目,还以为功放烧着了
739 点
739 ¥
发表于 2010-2-18 21:40 | 显示全部楼层
真多谢 Pass 老头
F5 已经很喜欢了, 期待啊!
2223 点
2130 ¥
发表于 2010-2-18 22:53 | 显示全部楼层
期待啊,我的F5还没做呢。
264 点
260 ¥
发表于 2010-2-18 23:08 | 显示全部楼层
换成12对金封管就爽了,看来我的120只IRF240有用了。
1190 点
1214 ¥
发表于 2010-3-3 08:22 | 显示全部楼层
非常喜欢  F5的高音  现在正用在  电子分频系统做高音功放  正缺一款好的 中低音  这个应该用得上
