[器件资料] LT凌特公司型号
[复制链接] 查看: 4865|回复: 1
865 点
749 ¥
发表于 2009-12-5 15:37 | 显示全部楼层
LT凌特公司型号
凌特公司(Linear Technology Corporation)生产的常用集成电路原厂型号
凌特公司(Linear Technology Corporation)生产的常用集成电路原厂型号,主要内容有放大器、数据转换器、线性稳压器、电源和电机控制、电池管理和充电、接口电路、基准源和相关应用笔记。
LT1001
LT1002
LT1006
LT1006S8
LT1007
LT1008
LT1010
LT1012
LT1012S8
LT1013/LT1014
LT1022
LT1024
LT1028
LT1037
LT1055
LT1056
LT1055S8/LT1056S8
LT1057
LT1057S8/LT1057IS8
LT1058
LT1077
LT1078/LT1079
Amplifiers
LT1097
LT1112/LT1114
LT1113
LT1115
LT1124/LT1125
Amplifiers
LT1126/LT1127
Operational Amplifiers
LT1128
Notice)
LT1169
LT1178/LT1179
Amplifiers (Spec. Notice)
LT1218/LT1219
LT1366/LT1367/LT1368/LT1369
Output Op Amps
LT1413
LT1457
LT1462/LT1463
Current JFET Input Op Amps
LT1464/LT1465
LT1466L/LT1467L
Output Op Amps
LT1490/LT1491
Amps
LT1490A/LT1491A
Output Op Amps
LT1492/LT1493
Precision Op Amps
LT1494/LT1495/LT1496
and Output Op Amps
LT1498/LT1499
Precision C-Load Op Amps
LTC1541/LTC1542
LT1635
LT1636
LT1637
Output Op Amp
LT1638/LT1639
Rail Input and Output Op Amps
LT1677
LT1782
LT1783
LT1784
LT1787/LT1787HV Precision High-Side Current Sense Amplifier
LT1792
LT1793
LT1881/LT1882
Amps
LT1884/LT1885
Amps LT2078/LT2079
Amps
LT2178/LT2179
ZERO-DRIFT OPERATIONAL AMPLIFIERS
LTC1047
Capacitors
LTC1049
(Spec. Notice)
LTC1050
(Spec. Notice 2)
LTC1051/LTC1053
Internal Capacitor
LTC1052
LTC1052CS
LTC1150
Notice)
LTC1151
LTC1152
LTC1250
LTC2050
LTC2050HV
LTC2051/2
SECTION 2?高速放大器
LT1122
LT1187
LT1189
LT1190
LT1191
LT1192
LT1193
LT1194
LT1195
LT1206
LT1207
LT1208/LT1209
LT1210
LT1211/LT1212
Amps
LT1213/LT1214
Amps (Spec. Notice)
LT1215/LT1216
Amps
LT1217
LT1220
LT1221
LT1222
Notice)
LT1223
LT1224
LT1225
LT1226
LT1227
LT1228
LT1229/LT1230
LT1251/LT1256
LT1252
LT1253/LT1254
LT1259/LT1260
with Shutdown
LT1311
Optical Disk Drives
LT1351
LT1352/LT1353
LT1354
LT1355/LT1356
LT1357
LT1358/LT1359
LT1360
LT1361/LT1362
LT1363
LT1364/LT1365
LT1398/LT1399
with Shutdown
LT1468
LT1469
LT1497
LT1675
LT1630/LT1631
Precision Op Amp
LT1632/LT1633
Precision Op Amp
LT1795 Dual 500mA/50MHz Current Feedback Amplifier/xDSL Line Driver
LT1797
LT1806/LT1807 325MHz
Low Noise Precision Op Amp
LT1809/LT1810
Op Amp
LT1812
LT1813
LT1886
VIDEO MULTIPLEXERS
LT1203/LT1205
LT1204
POWER OUTPUT STAGE
LT1166
SECTION 3—仪表放大器
LTC1043
LTC1100
LT1101
Gain = 10 or 100)
LT1102
Gain = 10 or 100)
LT1167
(Spec. Notice)
LT1168
LT1193
LT1194
LT1920
SECTION 4?电源产品
无电感式DC/DC变换器
LT1026
LTC1044/7660
LTC1044A
LTC1044CS8
LTC1046
LT1054/1054L
Notice)
LTC1144
Shutdown
LTC1261
LTC1261L
LTC1262
LTC1263
LTC1429
LTC1502-3.3
LTC1503-1.8/LTC1503-2
Converters
LTC1514-3.3/LTC1514-5
Converters
with Low-Battery Comparator
LTC1515 Series
with Reset
LTC1516
LTC1517-3.3
Package
LTC1517-5
Package (Spec. Notice)
LTC1522
Notice)
LTC1550/LTC1551
(Spec. Notice)
LTC1550L/LTC1551L
Inverters
LT1682/LT1682-3.3/LT1682-5
Regulator
LTC1751/LTC1751-3.3/LTC1751-5
DC/DC Converters
LTC1754-3.3/LTC1754-5
Shutdown in SOT-23
LTC1928-5
LTC1986
LTC3200/LTC3200-5
LTC660
高端开关
LTC1155
Charge Pump
LTC1156
Charge Pump
LT1188
线性稳压器
LT1005
LT1020
LT1033
LT1035
LT1036
LT1038
LT1083/LT1084/LT1085
Regulators
LT1083/LT1084/LT1085 Fixed
Regulators
LT1086 Series
3.3V
LT1087
LT1117/LT1117-2.85/LT1117-3.3/LT1117-5
Regulators; Adjustable and Fixed 285V
LT1118-2.5/LT1118-285/LT1118-5
Sink Regulators Fixed 2.5V
LT1120
LT1120A
LT1121/LT1121-3.3/LT1121-5
Shutdown
LT1123
LT1129/LT1129-3.3/LT1129-5
Shutdown
LT1175
LT1185
LT1521/LT1521-3/LT1521-3.3/LT1521-5
Micropower Quiescent Current and Shutdown
LT1528
LT1529/LT1529-3.3/LT1529-5
LT1573
LT1575/LT1577
LT1579
LT1580/LT1580-2.5
LT1581/LT1581-2.5
LT1584/LT1585/LT1587
Regulators (Spec. Notice)
LT1585-1.5/LT1585A-1.5
GTL+ Regulators
LT1761 Series
LT1762 Series
LT1763 Series
LT1764 Series
LT1962 Series
LT1963
电源和电机控制
LTC1153
LTC1154
LTC1157
LT1158
LT1160/LT1162
Notice)
LT1161
LTC1163/LTC1165
LTC1177-5/LTC1177-12
LT1241–45
LT1246/LT1247
LT1248
LT1249
LTC1255
LT1336
LT1339
LT1432
LT1432-3.3
LTC1473
LTC1473L
LTC1477/LTC1478
LTC1479
LT1508
LT1509
LTC1558-3.3/LTC1558-5
LTC1559-3.3/LTC1559-5
LTC1623
LT1680
LTC1693
LTC1695
LT1725
LT1737
LT1922-1
LTC1982
开关稳压器
LT1070
LT1071
LT1072
LT1073
LT1074/LT1076
LT1076-5
LT1082
LT1103/LT1105
LT1106
LT1107
Notice)
LT1108
LT1109
LT1109A
Adjustable and Fixed 5V
LT1110
Frequency
LT1111
LTC1142/LTC1142-ADJ
Switching Regulators
LTC1143
LTC1147-3.3/LTC1147-5
Controllers
LTC1148/LTC1148-3.3/LTC1148-5
LTC1149/LTC1149-3.3/LTC1149-5
LTC1159/LTC1159-3.3/LTC1159-5
Switching Regulators (Spec. Notice)
LT1170/LT1171/LT1172
Regulators
LT1173
LTC1174/LTC1174-3.3/LTC1174-5
DC/DC Converter
LT1176/LT1176-5
LT1182/LT1183/LT1184/LT1184F
(Spec. Notice)
LT1186
LTC1265/LTC1265-3.3/LTC1265-5
Converters
LTC1266/LTC1266-3.3/LTC1266-5
P-Channel MOSFETs
LTC1267/LTC1267-ADJ/LTC1267-ADJ5
Step-Down Switching Regulators (Spec. Notice)
LT1268B/LT1268
LT1270/LT1270A
LT1271/LT1269
LT1300
Notice)
LT1301
Flash Memory
LT1302/LT1302-5
Fixed 5V DC/DC Converters (Spec. Notice)
LT1303/LT1303-5
Battery Detector Adjustable and Fixed 5V (Spec. Notice)
LT1304/LT1304-3.3/LT1304-5
Detector Active in Shutdown
LT1305
LT1306 Synchronous
Disconnect
LT1307/LT1307B
(Spec. Notice)
LT1308
LT1308A/LT1308B
Converter
LT1309
LT1316
(Spec. Notice)
LT1317/LT1317B
LT1370
LT1371
LT1372/LT1377
(Spec. Notice)
LT1373
LT1374
LT1375/
LT1424-5
LT1424-9
LT1425
LTC1430
LTC1430A
LTC1433/LTC1434
Converters
LTC1435
Regulator
LTC1435A
Regulator
LTC1436/LTC1436-PLL/LTC1437
LTC1438/LTC1439
LTC1474/LTC1475
Converters
LT1500/LT1501
LTC1504
(Spec. Notice)
LTC1504A
LT1506
LT1507
LTC1530
LT1533
LT1534
LTC1538-AUX/LTC1539
LTC1553
Pentium ?II Processor
LTC1553L
LT1572
LTC1574/LTC1574-3.3/LTC1574-5
Converters with Internal Schottky Diode
LT1576/LT1576-5 1.5A
LT1578
LT1610
LT1611
LT1613
LT1614
LT1615/LT1615-1
LT1616
LT1617/LT1617-1
LT1619
LTC1622
LTC1624
LTC1625
Regulator
LTC1626
LTC1627
LTC1628
Regulator
LTC1628-SYNC
Regulator
LTC1629
Regulator
LTC1649
LT1676
LTC1701
LTC1702
LTC1703
LTC1706-19
LTC1706-81
LTC1706-82
LTC1707
LTC1708-PG
Synchronous Buck Regulator Controller
LTC1709
Regulator
LTC1709-7
Regulator w/ VID
LTC1709-8/LTC1709-9
Switching Regulator
LTC1709
Regulator
LTC1735
LTC1735-1
LTC1736
Regulator
LTC1753
LT1767
LTC1771
LTC1772
SOT-23
LTC1773
LTC1775
Switching Regulator
LT1776
LT1777
LTC1779
LT1786F
LT1872
LT1873
5-Bit VID
LTC1874
LTC1876
Controller with Step-Up Regulator
LTC1877
LTC1878
LT1929
Regulators
LT1930
LT1931
LT1948
LT1949
LT1949-1
LT1959
LTC3401
LTC3402
LTC3404
电池管理和充电
LT1239
LTC1325
LT1505
LT1510
LT1511
Current Limiting
LT1512
Notice)
LT1513
LT1571
Voltage and Termination Flag
LT1620/LT1621
LTC1729 Series
LTC1731
LTC1732-4/LTC1732-4.2
LTC1734
LTC1759
LT1769
Limiting
热插拔控制
LTC1421
LTC1422
LT1640L/LT1640H
LT1641
LTC1642
LTC1643L/LTC1643H
LTC1645
PCMCIA主机和卡电源管理
LT1106
LTC1262
LT1312
LT1313
LTC1314/LTC1315
Switch Drivers
LTC1470/LTC1471
LTC1472
LTC1755/LTC1756
LTC1757A-1/LTC1757A-2
SECTION 5?接口
RS232/562 5-7
LT1030
LT1032
LT1039
LT1039A/LT1039A-16
LT1080
LT1081
LT1130A
LT1131A
LT1132A
LT1133A
LT1134A
LT1135A
Pump
LT1136A
LT1137A
LT1138A
LT1139A
LT1140A
Pump
LT1141A
Pump
LT1180A
LT1181A
LT1237
Receiver Active in SHUTDOWN
LT1280A
LT1281A
LTC1327
LT1330
in SHUTDOWN
LT1331
SHUTDOWN
LT1332
Output for Flash Memory
LTC1337
LTC1338
LT1341
LT1342
LTC1347
Receivers Active in SHUTDOWN (Spec. Notice)
LTC1348
LTC1349
LTC1350
LT1381
LTC1382
LTC1383
LTC1384
SHUTDOWN
LTC1385
LTC1386
LT1537
LT1780/LT1781
Protection
RS485
LTC485
LTC486
LTC487
LTC488/LTC489
LTC490
LTC491
LTC1480
LTC1481
LTC1482
Safe
LTC1483
LTC1484
LTC1485
LTC1487
Impedance
LTC1535
LTC1685
LTC1686/LTC1687
LTC1688/LTC1689
LTC1690
LT1785/LT1785A/LT1791LT1791A
Transceivers
V35
LTC1345
LTC1346A
AppleTalk ?
LTC1318
LTC1320
LTC1323
LTC1324
红外
LT1319
LT1328
多协议
LTC1321/LTC1322/LTC1335
LTC1334
LTC1343
LTC1344
LTC1344A
LTC1387
LTC1543
LTC1544
LTC1545
电平转换
LTC1045
(Spec. Notice)
VERY HIGH SPEED DIFFERENTIAL
LTC1518/LTC1519
LTC1520
SECTION 6?数据转换
模数转换器
LTC1090
LTC1091
LTC1092
LTC1093
LTC1094
LTC1095
LTC1096/LTC1096L/LTC1098/LTC1098LLow Voltage
Bit Serial I/O A/D Converters
LTC1099
LTC1196/LTC1198
LTC1197/LTC1197L/LTC1199/LTC1199L
Auto Shutdown
LTC1272
LTC1273/LTC1275/LTC1276
Reference (Spec. Notice)
LTC1274/LTC1277
LTC1278
LTC1279
LTC1282
LTC1283
LTC1285/LTC1288
Packages (Spec. Notice)
LTC1286/LTC1298
Packages
LTC1287
LTC1289
LTC1290
LTC1291
LTC1292/LTC1297
LTC1293/LTC1294/LTC1296
Notice)
LTC1380/LTC1393
多路转换器
LTC1392
Monitor
LTC1400
LTC1401
LTC1402
LTC1404
LTC1406
LTC1409
LTC1410
LTC1412
LTC1414
LTC1415
LTC1416
LTC1417
LTC1418
LTC1419
LTC1420
LTC1594/LTC1598
A/D Converters
LTC1594L/LTC1598L
I/O A/D Converters
LTC1604
LTC1605
LTC1605-1/LTC1605-2
LTC1606
LTC1608 High Speed
LTC2400
LTC2401/LTC2402
in MSOP-10
LTC2404/LTC2408
LTC2410
LTC2411
LTC2413
Rejection
LTC2420
LTC2424/LTC2428 4/8 Channel 20-Bit. μPower No Latency Delta-Sigma ? ADC
DIGITAL-TO-ANALOG CONVERTERS
LTC1257
Notice)
LTC1329-10/LTC1329-50/LTC1329A-50
Converter (Spec. Notice)
LTC1426
LTC1427-50
Interface
LTC1428-50
LTC1446/LTC1446L
LTC1448
LTC1450/LTC1450L
SSOP
LTC1451/LTC1452/LTC1453
LTC1454/LTC1454L
LTC1456
LTC1458/LTC1458L
LTC1590
LTC1591/LTC1597
4-Quadrant Resistors
LTC1595/LTC1596/LTC1596-1
LTC1599
LTC1650
LTC1654
LTC1655/LTC1655L
Package
LTC1657L
LTC1657
LTC1658
LTC1659
LTC1662
LTC1663
LTC1664
LTC1665/1660
LTC1668
LTC7541A
LTC7543/LTC8143
LTC7545A
LTC8043
MULTIPLEXERS
LTC1390
LTC1391
SECTION 7?基准
LTZ1000
LTZ1000A
LT1004
LT1009 Series
LT1019
LT1021
LT1027
LT1029
LT1031
LT1034-1.2/LT1034-2.5
LT1236
LTC1258 Series Micropower Low Dropout Reference
LT1389
LT1431
LT1460-2.5
LT1460S3 (SOT-23)
LT1460-5
LT1460-10
LT1461-2.5
LT1634
LT1790-2.5
LTC1798 Series
SECTION 8?单片晶体滤波器
LTC1059
LTC1059CS
LTC1060
LTC1060CS
LTC1061
LTC1061CS
LTC1062
LTC1063
(Spec. Notice)
LTC1064
LTC1064-1
Notice)
LTC1064-2
LTC1064-3
(Spec. Notice)
LTC1064-4
Notice)
LTC1064-7
LTC1065
Filter (Spec. Notice)
LTC1066-1
Phase Lowpass Filter (Spec. Notice)
LTC1067/LTC1067-50
Building Block
LTC1068
LTC1069-1
LTC1069-6
LTC1069-7
LTC1164
LTC1164-5
Filter
LTC1164-6
Lowpass Filter
LTC1164-7
LTC1164-8
Adjustable Gain
LTC1264
LTC1264-7
LTC1560-1
LTC1562
Notice)
LTC1563-2/LTC1563-3
LTC1565-31
LTC1562-2
LTC1569-6
LTC1569-7
SECTION 9?微控制器监视电路
LTC690/LTC691/LTC694/LTC695
LTC692/LTC693
LTC694-3.3/LTC695-3.3
LTC699
LTC1232
LTC1235
(Spec. Notice)
LTC1326/LTC1326-2.5
Notice)
LTC1536
LTC1726
Watchdog Timer
LTC1727/LTC1728
lead SOT-23 packages
LTC1985-1.8
Output in a 5-Lead SOT-23 Package
SECTION 10?比较器
LT1011
LT1015
LT1016
LT1017/LT1018
LTC1040
LTC1041
LTC1042
LT1116
LT1394
LTC1440/LTC1441/LTC1442
LTC1443/LTC1444/LTC1445
LTC1531
LTC1540
LT1671
LT1712
LT1713
LT1714
LT1719
LT1720
LT1721
LTC1841/LTC1842/LTC1843
SECTION 11?特殊功能
LTK001
LTC201A/LTC202/LTC203
Analog Switches
LTC221/LTC222
Switches with Data Latches
LT1025
LTC1043
LTC1043CS
LT1088
LTC1340
LTC1555/LTC1556
LTC1555L
LTC1555L-1.8
LT1684
LTC1694
LTC1694-1
LTC1710
644 点
643 ¥
发表于 2009-12-22 23:38 | 显示全部楼层
没有什么实际意义啊? 要有应用线路或参数好
