127 点
127 ¥
发表于 2009-11-2 01:28 | 显示全部楼层
我的APE播放器升级前证书已备份到U盘,升级时一直插着,升级完0808后,显示“机器未验证”,进不了主菜单了,机器不能用。后来关机一段时间后,重新开机又正常了,已验证升级到0808,然后我开始准备播放歌曲,插入U盘开机播放,可是按下PLAY后显示屏幕突然没有了显示,只是屏幕背光亮,没有字符显示,再开机也无字符显示了,按机面键都无用。难道是显示屏幕坏了,请帮助我?多谢!!!!!!
379
广东深圳
2616 点
2644 ¥
发表于 2009-11-2 02:00 | 显示全部楼层
是什么版本升过来的?必须是先0601,然后0808-然后试验开机后用遥控器按:3.4.3.ok
127 点
127 ¥
 楼主| 发表于 2009-11-2 22:11 | 显示全部楼层
如果不是0601版本升过来的怎么办? 现在开机没有任何显示,只有屏幕背光亮,按3.4.3 OK后关机。
127 点
127 ¥
 楼主| 发表于 2009-11-2 22:53 | 显示全部楼层
这是开机运行状态!
| S3C2440A USB Downloader ver R0.03 2004 Jan  |
USB: IN_ENDPOINT:1 OUT_ENDPOINT:3
FORMAT: <ADDR(DATA):4>+<SIZE(n+10):4>+<DATA:n>+<CS:2>
NOTE: Power off/on or press the reset button for 1 sec
      in order to get a valid USB device address.
NAND device: Manufacture ID: 0xec, Chip ID: 0x76 (Samsung K9D1208V0M)
Could not found stored vivi parameters. Use default vivi parameters.
Press Return to start the LINUX/Wince now, any other key for vivi
Copy linux kernel from 0x00050000 to 0x30008000, size = 0x00200000 ... done
zImage magic = 0x016f2818
Setup linux parameters at 0x30000100
linux command line is: "noinitrd root=/dev/mtdblock2 init=/linuxrc console=ttySAC0"
MACH_TYPE = 782
NOW, Booting Linux......
Uncompressing Linux............................................................................................................................... done, booting the kernel.
Linux version 2.6.24.7 (root@localhost.localdomain) (gcc version 3.4.1) #97 Fri Nov 6 15:03:53 CST 2009
CPU: ARM920T [41129200] revision 0 (ARMv4T), cr=c0007177
Machine: SMDK2440
ATAG_INITRD is deprecated; please update your bootloader.
Memory policy: ECC disabled, Data cache writeback
CPU S3C2440A (id 0x32440001)
S3C244X: core 405.000 MHz, memory 101.250 MHz, peripheral 50.625 MHz
S3C24XX Clocks, (c) 2004 Simtec Electronics
CLOCK: Slow mode (1.500 MHz), fast, MPLL on, UPLL on
CPU0: D VIVT write-back cache
CPU0: I cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets
CPU0: D cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 16256
Kernel command line: noinitrd root=/dev/mtdblock2 init=/linuxrc console=ttySAC0
irq: clearing pending status 02000000
irq: clearing subpending status 00000002
PID hash table entries: 256 (order: 8, 1024 bytes)
timer tcon=00000000, tcnt a4ca, tcfg 00000200,00000000, usec 00001e57
Console: colour dummy device 80x30
console [ttySAC0] enabled
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 64MB = 64MB total
Memory: 60732KB available (3692K code, 301K data, 112K init)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
net_namespace: 64 bytes
NET: Registered protocol family 16
S3C2410 Power Management, (c) 2004 Simtec Electronics
S3C2440: Initialising architecture
S3C2440: IRQ Support
S3C2440: Clock Support, DVS off
S3C24XX DMA Driver, (c) 2003-2004,2006 Simtec Electronics
DMA channel 0 at c4800000, irq 33
DMA channel 1 at c4800040, irq 34
DMA channel 2 at c4800080, irq 35
DMA channel 3 at c48000c0, irq 36
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
NetWinder Floating Point Emulator V0.97 (extended precision)
NTFS driver 2.1.29 [Flags: R/W].
fuse init (API version 7.9)
yaffs Oct  1 2009 18:43:15 Installing.
io scheduler noop registered
io scheduler anticipatory registered (default)
io scheduler deadline registered
io scheduler cfq registered
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
s3c2440-uart.0: s3c2410_serial0 at MMIO 0x50000000 (irq = 70) is a S3C2440
s3c2440-uart.1: s3c2410_serial1 at MMIO 0x50004000 (irq = 73) is a S3C2440
s3c2440-uart.2: s3c2410_serial2 at MMIO 0x50008000 (irq = 76) is a S3C2440
RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
loop: module loaded
dm9000 Ethernet Driver
eth0: dm9000 at c4804300,c4806304 IRQ 51 MAC: 00:e0:3d:f4:dd:f7
usbcore: registered new interface driver zd1211rw
console [netcon0] enabled
Machine: SMDK2440
TCP reno registered
loop: module loaded
netconsole: network logging started
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 50MHz system bus speed for PIO modes; override with idebus=xx
SET CF & IDE WAIT!now BWSCON=22511510
now begin cf_ide_init_default_hwifs()
have initialized interrupt for cf:EINT3
fla2612:INTMSK=6f7f3d85
GPFCON=000095aa
EXTINT0=00004040
GPBCON=00144555
GPBDAT=00000640
-1:no 0:ok CF_register_hw return -1
-1:no 0:ok ide_register_hw return -1
Driver 'sd' needs updating - please use bus_type methods
Generic platform RAM MTD, (c) 2004 Simtec Electronics
block2mtd: version $Revision: 1.30 $
S3C24XX NAND Driver, (c) 2004 Simtec Electronics
s3c2440-nand s3c2440-nand: Tacls=1, 9ns Twrph0=4 39ns, Twrph1=1 9ns
NAND device: Manufacturer ID: 0xec, Chip ID: 0x76 (Samsung NAND 64MiB 3,3V 8-bit)
NAND_ECC_NONE selected by board driver. This is not recommended !!
Scanning device for bad blocks
Creating 3 MTD partitions on "NAND 64MiB 3,3V 8-bit":
0x00000000-0x00020000 : "vivi"
0x00050000-0x00250000 : "kernel"
0x00250000-0x03ffc000 : "root"
s3c2410-ohci s3c2410-ohci: S3C24XX OHCI
s3c2410-ohci s3c2410-ohci: new USB bus registered, assigned bus number 1
s3c2410-ohci s3c2410-ohci: irq 42, io mem 0x49000000
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
Initializing USB Mass Storage driver...
usb 1-1: new full speed USB device using s3c2410-ohci and address 2
usb 1-1: configuration #1 chosen from 1 choice
scsi0 : SCSI emulation for USB Mass Storage devices
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mice: PS/2 mouse device common for all mice
S3C24XX RTC, (c) 2004,2006 Simtec Electronics
s3c2410-rtc s3c2410-rtc: rtc disabled, re-enabling
s3c2410-rtc s3c2410-rtc: rtc core: registered s3c as rtc0
mapped channel 2 to 0
s3c2440-sdi s3c2410-sdi: powered down.
s3c2440-sdi s3c2410-sdi: initialisation done.
s3c2440-sdi s3c2410-sdi: running at 0kHz (requested: 0kHz).
s3c2440-sdi s3c2410-sdi: running at 198kHz (requested: 197kHz).
mapped channel 10 to 2
mapped channel 9 to 1
UDA1341 audio driver initialized
TCP cubic registered
NET: Registered protocol family 17
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
ieee80211: 802.11 data/management/control stack, git-1.1.13
ieee80211: Copyright (C) 2004-2005 Intel Corporation <jketreno@linux.intel.com>
s3c2410-rtc s3c2410-rtc: setting system clock to 2009-11-02 23:01:24 UTC (1257202884)
yaffs: dev is 32505858 name is "mtdblock2"
yaffs: passed flags ""
yaffs: Attempting MTD mount on 31.2, "mtdblock2"
VFS: Mounted root (yaffs filesystem).
Freeing init memory: 112K
init started: BusyBox v1.10.1 (2008-04-20 01:24:00 CST)
starting pid 795, tty '': '/etc/init.d/rcS'
scsi 0:0:0:0: Direct-Access     Kingston DT 101 II        1.00 PQ: 0 ANSI: 2
sd 0:0:0:0: [sda] 3973120 512-byte hardware sectors (2034 MB)
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] Assuming drive cache: write through
sda: sda1
sd 0:0:0:0: [sda] Attached SCSI removable disk
sd 0:0:0:0: Attached scsi generic sg0 type 0
hotplug: applet not found
starting initial script
vm.dirty_expire_centisecs = 300
vm.min_free_kbytes = 12800
eth0: link down
pa_offset = 0x56000000
offset = 0x00000062
writed iVallue = 0x96
offset = 0x00000065
writed iVallue = 0xbe
Check MCU status...
ls: /mnt/*/llpupd*.gz: No such file or directory
Show line 1: 所有歌曲
Show line 2: 播放列表
Show line 3: 高级应用
Show line 4: 关闭机器
Mac address is 00:13:f6:6c:87:99
Checkwireless()
start http
Setting IP ...
eth0: link down
[02/Nov/2009:23:01:38 +0000] boa: server version Boa/0.94.13
[02/Nov/2009:23:01:38 +0000] boa: server built Feb 28 2004 at 21:47:23.
[02/Nov/2009:23:01:38 +0000] boa: starting server pid=887, port 80
Show line 1: 录制音乐
Show line 2: 压缩文件
Show line 3: 系统设置
Show line 4: 关于本机
Show line 1: 备份证书
Show line 2: 版本信息
Show line 3: 恢复出厂设置
Show line 1: >>> LLPlayer <<<
Show line 2:    V 1.1.1
Show line 3:    Build 0
Show line 4:    2009.08.08
127 点
127 ¥
 楼主| 发表于 2009-11-3 01:44 | 显示全部楼层
更新FIRMWARE后正常了!可是WAV格式文件不能播,是否还需要更新1005程序包吗?
2555
管理员 当前离线
Rank: 9Rank: 9Rank: 9
14140 点
3152 ¥
发表于 2009-11-3 09:29 | 显示全部楼层
可以更新一次!
记住一定备份证书!
