- 2020
- 1075 小时
- 2017-1-13
- 100
- 1
- 2721
- 1780
- 1
- 2020 点
- 1406 ¥
- 2005-1-16
以下为在楼主的基础上修改的部分(括号内为我的增注)
I prefer woofers with lower Xmax - Stop the presses!
Woofers with lower Xmax sound better
拥有更低的XMAX的低音单元有更好的声音?
Warning: This article appears, at first glance, to contain broad sweeping generalizations. I wouldn't generalize if I didn't have enough experience to see the trends. A generalization is simply something that's more true than not. In this discussion, I'm not referring to minor millimeter differences in midwoofers, but large Xmax differences in larger woofers.
注意:本文主要讨论大口径低音单体而非中低音的Xmax之差异。
I never gave it much thought as to why, in my experience, lower Xmax woofers sound better. What I did notice though is that this statement stirs up a few folks who would like to think that their super-ultra-Xmax woofers are the best sounding woofers available. This is the 2"+ peak to peak crowd who determines a subwoofer value by a dollar to displacement ratio. Bragging rights are important to some people, and when you get the right to brag about having the highest output, you definitely cannot brag about having the highest quality sound.
我从来没有对此思索很多,根据我的经验,冲程较短的低音喇叭声音较好.我之所以关注这个命题是因为有些人声称他们那些超级大冲程的低音喇叭是现有的声音最好的低音喇叭,这是些2英寸以上冲程(指P-P)的喇叭,有人定义超低音喇叭的性价比为单位美圆与空气徘量的比率(排量也就是有效辐射面积SD X 冲程Xmax,译者添加).吹牛是某些人的重大权利,但是当你吹嘘你的喇叭有最高的低音输出能力时,肯定地,你不能同时吹嘘声音的质量也是最好.(以上为hya1951兄的翻译,有修改)
Lower Xmax woofers, as a generalization, sound better. It's the result of a simple design philosophy. While increasing a woofer design's Xmax, at some point the woofer stops being a reproducer of music, and starts being a power tool of noise making. These "power tools" are more suitable for home theater where the typical sound being reproduced is noise anyway. But for music, forget it.
通常,小冲程的低音喇叭声音较好,这是简单的设计原则的结果.当增加低音喇叭的冲程时,它开始变成制造噪音的强大工具,这对于家庭影院倒市是蛮适合的-那些声音中到处都是噪声,但是如果要听音乐-忘了它吧.
I can summarize what I speculate are most of the issues:
我总结与思索的主要论点如下: (以上为hya1951兄的翻译,有修改)
Long voice coils have associated response problems. Look at any monster woofer's response in the lower midrange and you will surely see a massive peak and dip. Many short voice coil woofers don't have this problem. With some woofers, the initial peak is still audible even with a low 4th order rolloff. In fact, peaks are still audible even if completely filtered out - They re-appear lower in frequency as 3rd order harmonic distortion. This is why some subs are easily localized even when crossed over at 80 hz.
长音圈的低音喇叭有频率响应方面的问题.看那些怪物低音喇叭的中低频段的响应曲线,你必然会发现巨大的峰谷,很多短音圈的低音喇叭就没有这个问题.对于某些低音喇叭,这些低频峰即使用4阶低通滤波仍然可以听见.(注:可以采用陷波或者其他类型等化器来一定程度上改善)实际上这些低频峰即使经过完善的低通滤波仍然可以听闻,是通过3次谐波失真的形式出现的,这就是为什么即使分频点在80Hz,很多超低音还是很容易被定位(超低音本来应该是无指向性的). (以上为hya1951兄的翻译,有修改)
Large excursion woofers are typically designed to work with high power in smallish enclosures, making the stroke very non-linear at the extremes of operation due to extreme pressures. That results in distortion. This is a good read on the subject.
巨大冲程的低音喇叭通常设计用于在小箱子里承受大功率的,由于压力巨大,这种极端的操作当然会造成很大的非线性.这一点值得一读.(注:这段话值得商榷。我个人的理解,箱子容积越小,同等功率下需要的XMAX就越小。所以为小箱子大功率的设计,比起大箱子来对于XMAX的要求反而相对低了点。至于说压力引起的非线形?不明白作者具体所指,按字面的理解是运动的非线形,而这个恰恰是需要更大的XMAX才能保持的,这很好理解)(以上为hya1951兄的翻译,有修改)
Long voice coils generally have very high Le. Some begin rolling off at 80hz already.
长音圈通常有很高的电感量,有的从80Hz开始滚降.*(以上为hya1951兄的翻译,有修改)(这个比较少见啊,从80Hz开始那得需要多大的电感量啊,可能作者指的是怪兽级的了。再者,对于磁路的处理可以大幅度降低感抗的,这个需要指出)
Long voice coils generally have higher Le distortion - inductance changes greatly based on the coil's location in the gap.
长音圈通常有高的电感量畸变-电感量随着音圈在磁隙中位置的改变而变化极大. (以上为hya1951兄的翻译,有修改)(这个需要,而且可以,通过KLIPPLE测试系统得到。而且这个也应该是扬声器设计的时候就要考虑和优化的问题,我觉得归结为长音圈带来的有点冤枉了。而且,长冲程可以采用短VC+径向磁路以及各类变形磁路的设计啊,比如AURA的,JBL的专利等)
Large excursion woofers often have more mechanical operating noise - slapping voice coil leads, and air noise from high pressure escaping from the pole piece vent.
巨大冲程的低音喇叭通常有大的机械噪声-噪声来之于高速运动的音圈,高压的空气从管道边缘被释放. (以上为hya1951兄的翻译,有修改)(这个问题是由功率带来的,并且可以通过在各个位置上预留气压平衡孔以及对通孔的处理得到一定的改善。再者,降低到一定程度后,由于这些噪音来自箱子内部,在不对外辐射的前提下,或者说辐射出来的影响较小的前提下,就不用考虑了,已经被直接辐射的声压给覆盖了)
Large excursion woofers are required to have huge surrounds to support their excursion. Often these are poorly designed and suck-back or deform under heavy load, causing distortion. Or on the other side of this argument, to avoid deformation, the surrounds are made so thick and stiff that the Fs of the driver goes way up.
超长冲程喇叭的悬边必须很宽才能实现超长冲程的目的,通常都设计得不好,在高负载(指大功率)下变形,造成失真,从另一方面来说,为了避免变形失真,悬边很厚很硬,造成喇叭Fs上升. (以上为hya1951兄的翻译,有修改)(同上,这个也是设计的问题,不能加到大冲程的头上。只能说,大冲程的悬挂系统的线性要求比小冲程的要高。另外,上面作者说反了,悬边设计很硬,是为了降低Cms,让大功率下振幅不要那么大,Fs的上升是带来的负面作用,一般需要用重量来均衡此负面作用。换句话讲,Cms和Mmd/Mms共同控制了Fs。这个也是扬声器低频设计的两难,必须作出取舍和妥协。再者,扬声器许多参数都是相互关联和影响的,设计的时候就必须从系统的角度出来来考虑问题)
Related to the issue above, large excursion woofers often have poor bass extension and require active EQ to get a reasonable bass response.
从上面几点可以得出这个观点,那就是巨大冲程的低音喇叭通常有很差的低频延伸,需要有源EQ均衡电路来获得合理的低频响应. (以上为hya1951兄的翻译,有修改)(不敢苟同作者的看法。首先,如何得出大冲程就一定带来差的低频延伸?我看这话说反了,还是在怪兽的世界中本来就是反的?其次,用EQ来改善低频是可行的而且在HIEND系统中我觉得是必须的,但是不是简单的对某些频点的补偿,具体的分析有兴趣的朋友可以参考下一些专业音响的文献)
Larger surrounds mean less effective radiating area, and higher even order distortion lower in frequency. Look at the low end distortion of an XT25 tweeter for an example of the distortion created when a higher percentage of radiating area comes from the surround.
宽大的悬边意味着较小的有效辐射面积,以及在频率低端较高的偶次谐波失真.当悬边的面积相对于辐射面积有较高百分比时,就会造成这种失真,高音喇叭XT25就是一例. (以上为hya1951兄的翻译)(我觉得不能这么比。大冲程的扬声器,需要的是大的冲程,而不是大的悬边,更不是意味着宽的悬边。其次,关于有效辐射面积的计算,很多时候,是包含了部分悬边面积的,至于算进去多少,有兴趣的朋友可以去找下有关计算有效辐射面积的文献。作者表达的不清楚,实际上带来的问题是边的失真,以及边本身的辐射的声音,以及边反射回来和对CONE的干涉等等,所造成的失真。至于XT25高音,有兴趣的可以去找下该公司关于该高音的设计说明以及专利就明白了)
This is not related to sound quality, but is still very important: The large magnets required to move these large masses of voice coil and cone are occasionally so large that they can't be placed within 10 feet of a TV. Specifically, keep those damn magnets away from my expensive ISF'd RPTV.
这一点无关音质,但还是很重要,为了驱动大质量的音圈与音盆,巨型磁铁是必不可少的,以至于必须离开电视机10英尺以上,尤其要使这些磁铁远离我昂贵的ISF'd RPTV(以上为hya1951兄的翻译)(目前进入平板电视年代基本没CRT/CDT什么事了,所以这个也就不是问题了)
A good woofer design can minimize many of the problems listed above, but there's a point of diminishing returns. And here's the core statement of this article: The more output a woofer has, the more tradeoffs have to be made in it's design. You can disagree with portions of this explaination, but you can't disagree with the core statement. There are a few workarounds that help the situation, such as underhung motors like the ones used in Aurasound's subs, or the dual gap/short coil design used in Adire's XBL^2 subs. These help greatly, but many core design tradeoffs remain.
一个良好设计的低音喇叭可以尽量降低上述所列问题,但这儿有收益递减这一点,这篇文章的核心命题为:一个低音喇叭的低频输出越高,在设计中的权衡和折衷也越多,你可以不同意我部分的解释,但是不可能否认这个核心命题.有一些设计是很有帮助的,如Aurasound's超低音喇叭中突出下颚的驱动器,以及可怕的XBL^2 超低音喇叭中运用的双磁隙,双短音圈设计,这些都有巨大帮助,但是仍然保留很多(核心,磁心?)设计折衷方案
(以上为hya1951兄的翻译)(基本同意作者)
I don't want to take this argument too far either - too little Xmax is just as bad as too much.
不想扯得太远了,因为过小的冲程的单元也是很差的
所以,下面,作者开始谈数据了 |
