- 301
- 2703 小时
- 2025-1-17
- 50
- 2
- 38072
- 389
- 2
- 301 点
- 215 ¥
- 2008-3-21
楼主 |
发表于 2009-6-27 13:43
显示全部楼层
同意cabe,不对主板改动,通过主板内置IDE接口直接接2.5寸硬盘,我也没遇到问题,工作稳定。
查了一下,2.5寸硬盘(希捷的、日立的)的启动电流一般在1A,2*7805供电,所以问题应该不大。
关于UBS接口的兼容或或者说稳定性的问题,还需要解决。因为大多情况下,外接U盘和移动硬盘,APE都认得出来,但是总有偶尔认不出来的情况,下面是用串口抓的LOG
1) 插上U盘(移动硬盘?)开机,认不到U盘(移动硬盘?)的开机LOG:
s3c2410-ohci s3c2410-ohci: new USB bus registered, assigned bus number 1
s3c2410-ohci s3c2410-ohci: irq 42, io mem 0x49000000
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
Initializing USB Mass Storage driver...
usb 1-1: new full speed USB device using s3c2410-ohci and address 2
usb 1-1: device descriptor read/64, error -62
usb 1-1: new full speed USB device using s3c2410-ohci and address 3
usb 1-1: new full speed USB device using s3c2410-ohci and address 4
usb 1-1: device not accepting address 4, error -62
usb 1-1: new full speed USB device using s3c2410-ohci and address 5
usb 1-1: device not accepting address 5, error -62
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mice: PS/2 mouse device common for all mice
S3C24XX RTC, (c) 2004,2006 Simtec Electronics
2) 开机后,插拔U盘(移动硬盘?)仍然认不出的时候产生的LOG:
Setting IP ...
IP is 192.168.1.5
eth0: link down
usb 1-1: new full speed USB device using s3c2410-ohci and address 6
usb 1-1: new full speed USB device using s3c2410-ohci and address 7
usb 1-1: new full speed USB device using s3c2410-ohci and address 8
usb 1-1: device not accepting address 8, error -62
usb 1-1: new full speed USB device using s3c2410-ohci and address 9
usb 1-1: device not accepting address 9, error -62
Show line 1: 所有歌曲
Show line 2: 播放列表
Show line 3: 高级应用
Show line 4: 关闭机器
3) APE开机时,认得到U盘(移动硬盘?)的开机LOG:
s3c2410-ohci s3c2410-ohci: S3C24XX OHCI
usb 1-1: configuration #1 chosen from 1 choice
scsi0 : SCSI emulation for USB Mass Storage devices
偶遇到不认U盘或移动硬盘的时候(反复开关机、插拔都不凑效),我是这样处理的:
1)拔下U盘
2)选择“关闭机器”--〉“重启”
3)选择“关闭机器”--〉“关机” 或者 直接按遥控按钮关机
4)把U盘插回APE的USB接口上
5)开机
然后APE就可以找到USB接口上的设备了,我的机器上试过目前成功率100%
但是,刚才看了sun100的帖子,我的办法在他的机器上未能凑效,可能是因为机器脾气不同或者个体差异?
嗨!没有什么方法可以包治百病呀! |
