[音箱资料] 看------换喇叭边!!!
[复制链接] 查看: 16900|回复: 69
5387 点
5366 ¥
发表于 2009-6-18 16:30 | 显示全部楼层
《转帖》Speaker repair with DIY Newfoam kits
                    Speaker repair done cheap
5387 点
5366 ¥
 楼主| 发表于 2009-6-18 16:30 | 显示全部楼层
Product: Newfoam DIY kit lite for 6 1/2 inch diameter speaker
Manufacturer: Newfoam - USA
Approx. price: 34.95 USD (including worldwide shipping)
Reviewer: Hartmut Quaschik - TNT Germany
Reviewed: November, 2004
Some time ago a friend brought a pair of speakers for repair to me. They are old two way speakers from Epicure, US made. The surround of the woofers had rotten away, but my friend insisted on having them repaired, as he regarded them as sounding good enough to keep them longer. One woofer had lost its dustcap, but he gave it to me to attach it again.
参与人数 1经验 +6 收起 理由
lakerblue + 6
5387 点
5366 ¥
 楼主| 发表于 2009-6-18 16:31 | 显示全部楼层
There were several options to get a new surround:
1Buy a cheap fullrange of right size, fetch the (preferably cloth) surround
2Make new cloth surrounds from scratch - one of my other friends is doing this, but it is a lot of work, and pays only for the rework of very expensive vintage woofers
2Buy surrounds from Europe's big speaker parts company, located in Germany, but they sell only to business, not to private
4Buy new surrounds online from Newfoam, USA
5Indeed, Newfoam have a nice website, and offers surrounds in standard sizes for speakers. I sent them an email with the exact dimensions of the speaker frame and cone, and asked, which size it is in their list. They offer the kits in a light version ("Lite") and in a more comprehensive version ("Pro"). The Lite Kit contains the new surrounds, glue, instructions and a video (PAL or SECAM, both are available). The Pro Kit contains the same plus plastic shims and new dustcaps.
I then ordered a Newfoam DIY Lite Kit for 6 1/2 inch diameter speaker, because I wanted the reuse the old dustcaps. I used the online ordering method, paid with VISA card, and received the Lite Kit a week later.
The video has about 30min. lenght and shows all you have to know about speaker surround repair. Just two remarks on the video: first, the sound is bass heavy and the voice is booming, then the procedure of shortening the surround for woofers with smaller diameter is suspicious. The glue smells like wood glue, is white, and gets transparent after some hours.
DIY的忠诚少将
170 点
168 ¥
发表于 2009-6-18 16:32 | 显示全部楼层
怎么是E言
5387 点
5366 ¥
 楼主| 发表于 2009-6-18 16:32 | 显示全部楼层
Preparing the woofers
First, unscrew the woofers from the cabinet, marking the color codes of the cables on the woofer frame. Then, remove all the foam rests of the old surround from the basket and also from the cone.
5387 点
5366 ¥
 楼主| 发表于 2009-6-18 16:33 | 显示全部楼层
If there is no dustcap at this step of the procedure, make sure to avoid rotten surround falling into the speaker's voice coil gap. I used transparent packing tape for protecting the voice coil gap. Be sure to remove the tape shortly after, because it might get hard to remove later on.
5387 点
5366 ¥
 楼主| 发表于 2009-6-18 16:34 | 显示全部楼层
Alignining the voice coil
In this step, a shim has to placed in the voice coil gap, in order to align the voice coil equally spaced in the voice coil gap. If the the voice coil is not aligned correctly, it will rub and will make scratching noise then.
In order to do this, the old dustcaps have to be removed.
5387 点
5366 ¥
I am using paper as shims here, but plastic is much better, as it is elastic and provides a self centering function. At this point, I wished I had ordered the Pro Kit instead of the Lite Kit.
5387 点
5366 ¥
 楼主| 发表于 2009-6-18 16:35 | 显示全部楼层
Glueing the new surround to the cone
Apply plenty of glue to the edge of the cone. Then put some things under the cone, such that it comes out and is above frame level. This is necessary, because the the new surround must rest on the edge of the cone for some hours now. Use your finger or the handle of a spoon to press the surround onto the cone along the edge.
Then put the new surround on the cone.
5387 点
5366 ¥
 楼主| 发表于 2009-6-18 16:36 | 显示全部楼层
After some hours, when the glue has dried, check that the surround is well glued all over the edge.
As you note from this picture the glue has become transparent.
52
1003 点
915 ¥
不懂英文,看图学习!
5387 点
5366 ¥
Glueing the new surround to the frame
While keeping the cone with the new surround pushed up, apply glue to the frame. As you can see on the picture, I applied plenty of glue.
Then push the cone down, so that the surround is pressed into the glue of the frame. You can use a coffee cup or a glass, put it on the middle of the cone, and then leave it for some hours, or simply the next evening. Use your finger or the handle of a spoon to press the surround onto the frame along the edge.
5387 点
5366 ¥
 楼主| 发表于 2009-6-18 16:38 | 显示全部楼层
Making new dustcaps
Because I did order the Lite Kit, and unfortunately lost the dustcap of the second woofer, I had to made some dustcaps out of cardpaper. I used a pair of scissors the cut out circles of appropriate diameter, then sprayed them black, and then glued them onto the cone.
5387 点
5366 ¥
Finished
The third evening, when the glue of the dustcaps had become hard, I assembled the woofers to the cabinets again.
5387 点
5366 ¥
 楼主| 发表于 2009-6-18 16:39 | 显示全部楼层
Sound
Ok, I hooked them up and listened to them. They sounded right. But as I did not know how they sounded before, I really cannot say whether they sound the same as before.
Conclusions
I took me three evenings, but altogether not more than 60 minutes to repair these rotten woofers. I would have saved one evening and 20 minutes, if I had ordered the Pro Kit instead of the Lite Kit. Next time, I will order the Pro Kit.
What saved a lot of time was that the kit was complete, so that I did not go the shops and buy glue or something else.
86
4060 点
3675 ¥
发表于 2009-6-18 16:43 | 显示全部楼层
学习了 好贴
305 点
288 ¥
发表于 2009-6-18 16:47 | 显示全部楼层
E文看不懂,根据图来看,还是看懂了一些步骤,喇叭边在哪有卖的呢
102 点
152 ¥
发表于 2009-6-18 16:57 | 显示全部楼层
2157 点
2045 ¥
发表于 2009-6-18 17:07 | 显示全部楼层
好帖,学习了
262 点
262 ¥
发表于 2009-6-18 19:06 | 显示全部楼层
废了!
