513 点
12 ¥
发表于 2006-3-4 20:35 | 显示全部楼层
那里有全新正品Z11铁心卖?绕EL34单端输出牛用。
513 点
12 ¥
 楼主| 发表于 2006-3-7 09:18 | 显示全部楼层
Julien版提供单端el34好声单端电路
准备上单端el34有什么好提,谢!
292
nostalgia
19692 点
12949 ¥
发表于 2006-3-4 20:42 | 显示全部楼层
去胆艺轩询问一下fred,他可能有
292
nostalgia
19692 点
12949 ¥
发表于 2006-3-11 10:07 | 显示全部楼层
好声的电路还没发现,不敢擅做评价
常见的电路都还过得去
292
nostalgia
19692 点
12949 ¥
发表于 2006-3-12 22:08 | 显示全部楼层
用第二个图好了
513 点
12 ¥
 楼主| 发表于 2006-3-12 21:57 | 显示全部楼层
这几个图如何?
<img src="attachments/dvbbs/2006-3/2006312215623589.gif" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2006-3/2006312215623589.gif\');}" onmousewheel="return imgzoom(this);" alt="" /><img src="attachments/dvbbs/2006-3/2006312215638738.gif" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2006-3/2006312215638738.gif\');}" onmousewheel="return imgzoom(this);" alt="" /><img src="attachments/dvbbs/2006-3/200631221579423.gif" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2006-3/200631221579423.gif\');}" onmousewheel="return imgzoom(this);" alt="" />
513 点
12 ¥
 楼主| 发表于 2006-3-12 21:16 | 显示全部楼层
EL34单端
EL34单端胆机的制作 www.aspsky.net  2003-3-3  动网先锋 EL34电子管在音响发烧友中的知名度很高,在《高保真音响》2000年4月刊登的“最常见100种电子管排名”中,EL34高居榜首。国内外著名的电子管机生产厂家,有不少用EL34制作的电子管机名品。但是从功率输出级的电路形式来看,几乎都毫无例外的是推挽放大,原因是EL34的最大屏耗仅为25瓦,当采用单管单端放大时,如果按五极管或者超线性接法,最大不失真输出功率不超过12瓦,若是接成三极管,则只有6瓦左右。而采用推挽放大电路,就可以轻易的将输出功率做到三四十瓦,可见,在输出功率方面,推挽比单端大得多,但就音质和音色而言,单端机优于推挽机。笔者制作过的单端电子管机不少,有300B、2A3、EL34、FU15、FU50、FD422、FU7、6P3P、6N18P、6C33C等,也有好多发烧好友光临寒舍进行对比试听过,若要从音质价格比衡量,那么EL34无疑是最超值的,因为EL34的价格较低,差不多是300B的1/10,况且,此管不仅国内就有曙光、桂光、北京几种牌子,国外俄罗斯、捷克等国也在生产,选择余地很大。本文介绍的这台EL34单端功放,采用三极管接法,最大不失真输出功率有6瓦,介于2A3和300B的输出功率之间,用来推动雨后初晴LS 3/5A和用黑花岗岩制作的MOREL MW166+MDT32自摩箱,音色通透柔和,而且电路简单易制。 一、电路原理和特点整个电路使用两级放大,特点是不用负反馈。推动级采用半只12AX7,输出级采用一只EL34。将EL34接成三极管以后,内阻有700K欧之多,大约与300B与2A3相当,最佳负载范围在2-4千欧,负载阻抗大点则失真小,但输出也小,负载阻抗小则相反。本电路选用3.3千欧,使输出与失真两者兼顾,若从其输出特性曲线来看,EL34在三极管接法时虽然比五极管接法内阻小得多,线性也好得多,但线性仍然比不上直热管2A3和300B。如果不使用局部或者大环负反馈,其失真还是比较大的,但这种失真主要是偶次谐波失真,如果在不用负反馈的条件下减小这种失真呢?办法还是有的,这可以通过合理的选择推动管以及它的静态工作点、负载电阻来解决。本机采用高放大系数的著名电子管12AX7来作EL34的推动管,推动级和输出级的电路形式均为共阴极放大,这种放大电路的输入信号与输出信号相位相反,这样当推动管的电流增加时,输出管的电流减小;推动管的电流减小时,输出管的电流增加,因为三极管在小电流时的输出特性曲线是弯曲的,不是直线,所以会产生非线性失真,但是,这两个管子所产生的失真方向是相反的,所以可以互相抵消一部分。假如推动级一点失真没有,则输出级产生的失真全部出现在负载扬声器上。但是如果适当选择推动管的工作点和交流负载电阻,故意使这一级产生的失真程度与输出级大致相当,就可以利用他的抵消作用使负载扬声器上的失真大大减小。本机中推动级12AX7的静态电流设计为0.7mA左右,使之位于输出特性曲线的弯曲部分,这一级的交流负载电阻是其屏极电阻(150千欧)和下一级栅极电阻(82千欧)的并联值,约为53千欧,在这种情况下,用示波器观察输出波形可以看到,当因为输入信号过大而产生过载失真时,正弦波的顶部是圆滑的变钝,这就意味着本功放在过载时非线性失真的增加速度是比较缓慢的,使本功放虽然输出功率不大,但是听感甚佳。本机输出电路和推动级一样使用自给偏压,这种电路比较简单,并且对输出管有一定的保护作用,EL34的静态工作点如下:屏阴极电压:Ua=360V 屏极电流Ia=63mA 栅极负栅压Ug=-27V 静态屏耗Pa=360×0.063=22.6W,小于其最大屏耗25W,较安全电源电路采用电子管5Z4P作全波整流,滤波电路采用CLC式π型滤波,这种滤波方式的残留纹波形式近似于正弦波,不影响听感。整流管采用旁热式的5Z4PA,而不采用直热式的5Z3P或5Z2P,因为直热管的灯丝热的特别快,不等EL34的灯丝热起来,直流高压就加到屏极和阴极之间了,这样长久下去会影响功率管的使用寿命。即使是采用了5Z4P的情况下,其阴极还是比EL34热的快,但毕竟时间差大大缩短了。请不要小看这一点,有许多采用晶体管整流的电子管机器,使用不到一年,电子管就严重老化,阴极发射能力大大降低,而一些使用电子管整流的收音机,用上十几年仍不减当年。二、元器件选择与制作前级放大管可以使用12AX7、6N4等双三极管,也可以每声道使用一只6G2或6AT6,只是早年在电子管收音机中使用的二极三极复合管,其中三极管部分的特性与半只12AX7相同。输出管也叫6CA7,前苏联的老型号叫6N27C。现在有很多牌子的可以选择,它们的基本结构相同,音色略有差别。笔者使用的是我国曙光,整流管采用国产5Z4PA,最大整流电流为140mA。输出变压器的素质决定了整机性能的优劣,所以是成功的关键所在。由于本机没有使用负反馈,故输出变压器的频响几乎就决定了本机的频响,那么,怎么简单的判断一个变压器的频响究竟如何呢?我们知道,决定变压器频响的主要因数是他的初级电感和漏感,对于一个好的输出变压器,二者之间的比值应该在1000以上,笔者用DL6423数字电容电感表测量过欧博的300B输出变压器,它的初级电感约为11H,漏感仅10.6mH。具体测量方法如下:先用20H档测初级线圈的电感,记下
513 点
12 ¥
 楼主| 发表于 2006-3-12 12:20 | 显示全部楼层
Julien版提供单端el34三极管接法电路
想做个简单的EL34的单端电路。
