- 11
- 2 小时
- 2021-2-2
- 40
- 97400
- 10
- 11 点
- 11 ¥
- 2009-4-18
楼主 |
发表于 2009-4-21 16:22
显示全部楼层
参数。。。。。忘记了发上去
AUTOTEK美国官方网站:http://www.maxxsonics.com/autotek/
SPECIFICATIONS(规格):
OUTPUT POWER @1% THD, 100Hz, 14.4 VOLTS
Mono @ 4ohm 620 watts
Mono @ 2ohm 1074 watts
Mono @ 1ohm 772 watts
OUTPUT POWER @ 5% THD,100Hz, 14.4 VOLTS
Mono @ 4ohm 698 watts
Mono @ 2ohm 1190 watts
Mono @ 1ohm 1750 watts
Distortion at rated power, 100Hz, 14.4V 1.4% 1 ohm
Efficiency at 1/3 power, 1%THD, lowest impedance 66.2%
Efficiency at full power, 1%THD, lowest impedance 69.9%
Maximum Current Consumption 170amps@5%THD,1750watts
Input Sensitivity 200mV to 10V
Frequency Response (+/-3db) 12Hz - 250 Hz
S/N (A-weighted, 1-watt) -52dBA
DampingFactor@100Hz, 4ohms 25watts 31.55
Idle Current 3.2A
Crossover Slope 24 dB
Crossover Range 35Hz - 250Hz
Bass Boost 0dB - 18 dB @ 45 Hz
Subsonic 12Hz - 35Hz
Dimensions 14 1/4" x 10" x 2" |
