- 364
- 767 小时
- 2024-9-27
- 50
- 33875
- 416
- 364 点
- 364 ¥
- 2008-1-12
不一样!摘录厂方说明:
“经典5350SE是建造在一个模块化的方式,有独立的功放,前置放大器和远程音量控制电路板,连接计算机等级扁平电缆,插头,插座。 It features a passive pre-amp circuit, providing no additional gain to the source signal.它采用被动的前置放大器电路,提供任何额外的收益来源的信号。 Although not strictly necessary, it can be configured with an active pre-amp if required, by plugging in an optional gain board which can be configured in steps of 3, 6 or 9 dB.虽然不是绝对必要,它可以配置积极前置放大器如果需要的话,堵在了一个可选增益局可以配置在步骤3 , 6或9个分贝。 An optional MM or MC Phono pre-amp can also be plugged in to further increase the flexibility of this fine integrated amplifier.一个可选的MM或MC唱机前置放大器也可插入进一步增加灵活性,这一罚款综合放大器。
To accommodate Bi-wiring and Bi-amping, the Classic 5350SE is fitted with 2 pairs of high current speaker binding posts plus separate pre-amp output and power amp input sockets.为了适应双布线和双路功放推动,典型5350SE配备2对高电流发言约束力的职位,外加前置放大器输出和功放输入插座。 Speaker A/B selection is switchable from the front panel.演讲者的A / B选择开关的前面板。 Joining and separating the pre/power sections is achieved with a switch on the rear panel, which is recessed to avoid accidental use.连接和分离的前/电源部分实现了开关后面板,这是凹进,以避免意外使用。 Typically this would be used when connecting an external device such as a subwoofer or graphic equaliser.通常情况下这将是用于连接外部设备,如低音或图形扳平。 The Classic 5350SE also hosts a front panel mounted headphone socket, which is unusual in modern integrated amplifiers.经典5350SE也主机前面板安装耳机插座,这是不同寻常的现代综合放大器。
Short circuit, DC offset and anti-thump protection circuitry makes the Classic 5350SE a sophisticated, user friendly integrated amplifier, with a technical performance close to the best that can be achieved.短路,直流偏移和反扑通保护电路使经典5350SE一个复杂的,用户友好的集成放大器,以技术性能接近的最好的是可以实现的。
For the technically minded, the Classic 5350SE uses a high current, N channel only, MOS-FET power output stage, driven by a P channel MOS-FET phase splitter and double differential voltage amplifier with symmetrical class A driver, to achieve ultra-low distortion and high speed with minimal negative feedback.在技术上头脑,经典5350SE使用一个高电流, N通道只,场效应晶体管的输出功率阶段的推动下,一个P通道MOS管场效应管分相器和双差动电压放大器对称A级驱动器,以实现超低失真和高速最小负反馈。 Therefore, the Classic 5350SE is able to avoid using any active circuitry in its pre-amp and still achieve high input sensitivity.因此,精英5350SE能够避免使用任何有源电路的前置放大器,仍然实现了高输入灵敏度。 The optional plug-in gain board uses all discrete transistor circuitry in a unique double differential servo controlled design achieving unbelievably low distortion and noise performance.可选插件增益局利用所有离散晶体管电路在一个独特的双微分伺服控制的设计实现令人难以置信的低失真和噪声性能。 ” |
