1369 点
1287 ¥
发表于 2009-1-15 22:34 | 显示全部楼层
弄到对13cm的两分频的喇叭 woofer是防弹布材料的
今天用专用设备和软件测试了woofer的Parameters数据
有些看得明白  但有很多参数不是很确定什么含义   以下附上部分数据
请高人讲下各个参数所代表的意思吧
两只单元都测了  以下贴附的部分参数是自己手算的两个单元的平均值)
General Report
Name                  Value           Unit                           Comment
Electrical Parameters
Re                       3.00            Ohm         IMORTED electrical voice coil resistance at DC
Le                       0.360            mH          frequency independent part of voice coil inductance
L2                       0.605            mH          para-inductance of voice coil
R2                       1.155             Ohm        electrical resistance due to eddy current losses
Cmes                   584.45          uF           electrical capacitance representing moving mass
Lces                    5.69              mH          electrical inductance representing driver compliance
Res                     17.41            Ohm         resistance due to mechanical losses
fs                        87.35              Hz            driver resonance frequency
Mechanical Parameters
(using laser)
Mms                     11.833           g           mechanical mass of driver diaphragm assembly including air load and voice coil
Mmd (Sd)              11.37              g           mechanical mass of voice coil and diaphragm without air load
Rms                      1.166              kg/s        mechanical resistance of total-driver losses
Cms                       0.28               mm/N     mechanical compliance of driver suspension
Kms                       3.57               N/mm     mechanical stiffness of driver suspension
Bl                          4.50               N/A        force factor (Bl product)
Lambda s               0.041                            suspension creep factor
Loss factors
Qtp                        0.84                            total Q-factor considering all losses
Qms                       5.59                           mechanical Q-factor of driver in free air considering Rms only
Qes                        0.96                            electrical Q-factor of driver in free air considering Re only
Qts                         0.82                            total Q-factor considering Re and Rms only
Vas                         3.1090            l             equivalent air volume of suspension
n0                          0.26             %           reference efficiency (2 pi-radiation using Re)
Lm                          85.32            dB           characteristic sound pressure level (SPL at 1m for 1W @ Re)
Lnom                      85.89             dB           nominal sensitivity (SPL at 1m for 1W @ Zn)
rmse Z                    13.64             %             root-mean-square fitting error of driver impedance Z(f)
rmse Hx                   3.14              %              root-mean-square fitting error of transfer function Hx (f)
Series resistor           0.00              Ohm          resistance of series resistor
Sd                          88.25            平方厘米     diaphragm area
HINT :           Increase Fmax to 20* fs to improve impedance fitting
U pp                        13.31             V              peak to peak value of voltage at terminals
U ac                         1.95              V rms         AC part of voltage signal
U dc                         0.00              V
U head                      31.3              dB             digital headroom of voltage signal
U SNR+D                   49.5              dB             ratio of signal to noise+distortion in voltage signal
fu noise                     26.7              Hz             frequency of noise+distortion maximum in voltage signal
I pp                           3.07              A              peak to peak value of current at terminals
I ac                           0.45              A rms         AC part of current signal
I dc                          -0.00              A
I head                       31.3              dB             digital headroom of current signal
I SNR+D                     8.0               dB             ratio of signal to noise+distortion in current signal
fi noise                       93.0              Hz             frequency of noise+distortion maximum in current signal
X pp                          3.81              mm            peak to peak value of displacement signal
X ac                           0.62             mm rms       AC part of displacement signal
X dc                          0.04              mm
X head                       34.0              dB              digital headroom of displacement signal
fx cutoff                                          Hz              frequency of highest valid line in displacement signal
p pp                           0.03             mV               peak to peak value of microphone signal
p ac                            0.00            mV rms           AC part of microphone signal
p head                        106.2           dB                digital headroom of microphone signal
p SNR+D                     -37.4             dB               ratio of signal to noise+distortion in microphone signal
fp noise                      269.2             Hz               frequency of noise+distortion maximum in microphone signal
f sample                      6000              Hz               sample frequency
N stim                        16384     number of samples   stimulus length
另外请教   这对喇叭是不是做闭箱比较合适呀?  看Q0比较高的说   高手给写建议
想自己动手做对箱子
1369 点
1287 ¥
 楼主| 发表于 2009-1-15 23:13 | 显示全部楼层
期待~~~~~~~~~
1369 点
1287 ¥
 楼主| 发表于 2009-1-16 00:07 | 显示全部楼层
知道的朋友请进来解惑  先谢过了!
荣誉版主 当前离线
2020 点
1406 ¥
发表于 2009-1-16 13:57 | 显示全部楼层
这是什么测试系统?K开头那个?
喇叭你煲过没有?测试时温度多少?看参数这个喇叭适合做开口箱,勉强可以做密闭箱
只是对于这个单元来讲,你要做二分频,当低音用,但是此单元FS较高而CMS太小(所以开始怀疑是温度或者未煲开的缘故),低频下潜欠奉,自己考虑吧。个人建议你最少要找一个FS〈50Hz的130MM单元做低音
1369 点
1287 ¥
 楼主| 发表于 2009-1-16 20:33 | 显示全部楼层
原帖由 1999 于 2009-1-16 13:57 发表
这是什么测试系统?K开头那个?
只是对于这个单元来讲,你要做二分频,当低音用,但是此单元FS较高而CMS太小(所以开始怀疑是 ...
呵呵  没办法  目前准备先用这对单元练练手
没煲过  煲了以后估计f0能下降6到10Hz的样子吧   测试温度就室温  好象开了空调  估计20度左右  自由空气中测试的
测试系统我一下想不起来了  记忆当中好象是DB什么什么的   也不晓得记错了没
1369 点
1287 ¥
 楼主| 发表于 2009-1-16 21:25 | 显示全部楼层
大家给我点建议  上面那些参数都是什么意思呢  想学习一下
谢谢
8619 点
7504 ¥
社区贡献 论坛版主 优秀版主 乐于助人
发表于 2009-1-16 22:15 | 显示全部楼层
其实,都写在后面,还挺具体的.
比如第一项:
Re                       3.00            Ohm         IMPORTED electrical voice coil resistance at DC
就是,Re  3.00 欧姆     重要的电音圈直流阻抗
第二项
Le  0.36mH 频率无关的音圈电感
如果还需要了解这些参数的具体意义,只能找一些书来看并上网搜索了.
1369 点
1287 ¥
 楼主| 发表于 2009-1-16 22:34 | 显示全部楼层
哦  我只晓得几个主要参数什么意思
许多都不清楚  特别是比较相近的几个  呵呵
谢谢o版
1369 点
1287 ¥
 楼主| 发表于 2009-1-16 22:36 | 显示全部楼层
原帖由 okra 于 2009-1-16 22:15 发表
其实,都写在后面,还挺具体的.
比如第一项:
第二项 ...
那这对喇叭适合做什么箱子呢?q高了点
想自己动手做对书架玩玩  给点建议吧  嘿嘿
1369 点
1287 ¥
 楼主| 发表于 2009-1-17 12:45 | 显示全部楼层
大家进来交流交流~~~
