- 19692
- 17781 小时
- 2025-4-25
- 150
- 17
- 2492
- 18343
- 17
- 19692 点
- 12949 ¥
- 2004-12-23
抄一段:
Description: Three-way, floorstanding loudspeaker. Drive-units: Scan-Speak 1" silk ring-radiator tweeter, Audio Technology 6" pulp-cone midrange unit, two SEAS 12" aluminum/magnesium-cone woofers. Crossover frequencies: 300Hz, 4kHz. Frequency range: 22Hz–40kHz. Sensitivity: 92dB/W/m. Nominal impedance: 4 ohms.
Dimensions: 53.5" (1360mm) H by 25.6" (650mm) W by 19.7" (500mm) D. Weight: 165 lbs (75kg).
Finishes: violin red, slate gray.
Serial number of units reviewed: 003.
Price: $40,000/pair. Approximate number of dealers: 12.
Manufacturer: Sonus Faber, 36057 Arcugnano (Vi), Italy. Tel: (39) 444-288788. Fax: (39) 444-288722. Web: www.sonusfaber.com
从这个来看,分频点是L版说的300Hz和4KHz,意味着AT的6寸单元要负责大部分。单元也如L版所述。 |
