1634 点
1187 ¥
发表于 2026-4-22 16:22 | 显示全部楼层
这几年多款曲线图示测胆仪面市,不少胆机爱好者都添置了“核”武器,有了曲线,画图设计电路也方便了,有些朋友上升到想用仿真电路验证一下设计,仿真需要模型,以前的有些前辈已经结合多种办法建立和分享了好多电子管的模型(功德无量!点赞)。
三极管的模型不难,难的是多极管模型,需要很多次的反复操作和学习,多极管的帘栅电流很关键,没有帘栅流的模型是废的,仿真时跑不出帘栅电流。所以,当我学了一丁点皮毛的时候,我就沾沾自喜,迫不及待想做一个分享。水平有限,如有错漏,请批判并指正以免因愚学的差错误导别人。拟合软件在这里下载(有可能被屏蔽打不开):http://www.dmitrynizh.com/tubeparams_image.htm
话不多,以图为例,不明之处不及解释,请包涵谅解。
完!
**** 6J8P ******************************************
* Created on 04/22/2026 20:43 using paint_kip.jar
* www.dmitrynizh.com/tubeparams_image.htm
* Plate Curves image file: 6J8P.jpg
* Data source link: <plate curves URL>
.SUBCKT 6J8P P G2 G K ; LTSpice tetrode.asy pinout
* .SUBCKT 6J8P P G K G2 ; Koren Pentode Pspice pinout
+ PARAMS: MU=20 KG1=3695 KP=150 KVB=12 VCT=0.115 EX=1.4 KG2=4200 KNEE=4.2 KVC=2.082
+ KLAM=2.209E-8 KLAMG=6.9E-5   KNK=-0.044 KNG=0.006 KNPL=50 KNSL=11 KNPR=120 KNSR=29
+ CCG=7P CGP=0.007P CCP=7P RGI=2000.0
* Vp_MAX=400 Ip_MAX=12 Vg_step=0.5 Vg_start=0 Vg_count=11
* X_MIN=98 Y_MIN=147 X_SIZE=958 Y_SIZE=455 FSZ_X=1616 FSZ_Y=876 XYGrid=false
* Rp=1400 Vg_ac=20 P_max=2.8 Vg_qui=-2.5 Vp_qui=300
* showLoadLine=n showIp=y isDHP=n isPP=n isAsymPP=n isUL=n showDissipLimit=y
* showIg1=n isInputSnapped=y addLocalNFB=n
* XYProjections=n harmonicPlot=y dissipPlot=n
* UL=0.43 EG2=100 gridLevel2=n addKink=y isTanhKnee=n advSigmoid=n
RE1  7 0  1G    ; DUMMY SO NODE 7 HAS 2 CONNECTIONS
E1   7 0  VALUE=  ; E1 BREAKS UP LONG EQUATION FOR G1.
+{V(G2,K)/KP*LOG(1+EXP((1/MU+(VCT+V(G,K))/SQRT(KVB+V(G2,K)*V(G2,K)))*KP))}
RE2  6 0  1G    ; DUMMY SO NODE 6 HAS 2 CONNECTIONS
E2  6 0  VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))} ; Kg1 times KIT current
RE21 21 0 1
E21  21 0 VALUE={V(6)/KG1*ATAN(V(P,K)/KNEE)} ; Ip with knee but no slope and no kink
RE22 22 0 1 ; E22: kink curr deviation for plate
E22  22 0 VALUE={V(21)*LIMIT(KNK-V(G,K)*KNG,0,0.3)*(-ATAN((V(P,K)-KNPL)/KNSL)+ATAN((V(P,K)-KNPR)/KNSR))}
G1   P  K  VALUE={V(21)*(1+KLAMG*V(P,K))+KLAM*V(P,K) + V(22)}
* Alexander Gurskii screen current, see audioXpress 2/2011, with slope and kink added
RE43 43 K 1G ; Dummy
E43  43 G2 VALUE={0} ; Dummy
G2   43 K  VALUE={V(6)/KG2*(KVC-ATAN(V(P,K)/KNEE))/(1+KLAMG*V(P,K))-V(22)}
RCP  P K  1G     ; FOR CONVERGENCE
C1   K G  {CCG}  ; CATHODE-GRID 1
C2   G P  {CGP}  ; GRID 1-PLATE
C3   K P  {CCP}  ; CATHODE-PLATE
R1   G 5  {RGI}  ; FOR GRID CURRENT
D3   5 K  DX     ; FOR GRID CURRENT }
.MODEL DX D(IS=1N RS=1 CJO=10PF TT=1N)
.ENDS
参与人数 2经验 +2 魅力 +4 收起 理由
tailai_chen + 2 + 2 牛而逼之
tipware + 2 很给力!
454 点
329 ¥
发表于 2026-4-22 19:15 | 显示全部楼层
多级管要勾选KINK选项,否则仿真时没有帘栅极电流。
参与人数 1经验 +2 魅力 +2 收起 理由
壳壳 + 2 + 2 老师说的对
1634 点
1187 ¥
 楼主| 发表于 2026-4-22 16:31 | 显示全部楼层
另一个讨论仿真拟合的帖子:diyAudio -- Model Paint Tools Tutorial | diyAudio  https://www.diyaudio.com/communi ... ls-tutorial.310199/
55 点
49 ¥
发表于 2026-4-22 16:33 | 显示全部楼层
这个软件还有负载线功能,建模做好后勾选Loadline for load Rp可以设置负载线计算谐波失真和增益等
7 点
5 ¥
发表于 2026-4-22 21:06 | 显示全部楼层
太好了,要认真实践!!!
7 点
5 ¥
发表于 2026-4-22 21:38 | 显示全部楼层
6J8P这几个字怎么打上去的?
550 点
565 ¥
发表于 2026-4-22 23:44 来自手机端 | 显示全部楼层
感谢壳爷的分享精神
1634 点
1187 ¥
 楼主| 发表于 2026-4-23 22:36 | 显示全部楼层
2P29S
**** 2P29S ******************************************
* Created on 04/23/2026 22:36 using paint_kip.jar
* Plate Curves image file: 2P29S.jpg
.SUBCKT 2P29S P G2 G K ; LTSpice tetrode.asy pinout
* .SUBCKT 2P29S P G K G2 ; Koren Pentode Pspice pinout
+ PARAMS: MU=10 KG1=4840 KP=156 KVB=12 VCT=0.2 EX=1.47 KG2=4200 KNEE=13.08 KVC=1.67
+ KLAM=2E-6 KLAMG=3E-4 KNEE2=20 KNEX=30  KNK=-0.044 KNG=0.006 KNPL=50 KNSL=11 KNPR=120 KNSR=29
+ CCG=5P CGP=0.06P CCP=6P RGI=2000.0
* Vp_MAX=300 Ip_MAX=30 Vg_step=1 Vg_start=0 Vg_count=13
* X_MIN=61 Y_MIN=44 X_SIZE=950 Y_SIZE=454 FSZ_X=1616 FSZ_Y=876 XYGrid=false
* Rp=1400 Vg_ac=20 P_max=2 Vg_qui=-6 Vp_qui=300
* UL=0.43 EG2=120 gridLevel2=n addKink=y isTanhKnee=y advSigmoid=n
RE21 21 0 1
E21  21 0 VALUE={V(6)/KG1*ATAN((V(P,K)+KNEX)/KNEE)*TANH(V(P,K)/KNEE2)} ; Ip with knee but no slope and no kink
G2   43 K  VALUE={V(6)/KG2*(KVC-ATAN((V(P,K)+KNEX)/KNEE)*TANH(V(P,K)/KNEE2))/(1+KLAMG*V(P,K))-V(22)}
.ENDS
1634 点
1187 ¥
 楼主| 发表于 2026-4-23 22:49 | 显示全部楼层
4J1S
**** 4J1S ******************************************
* Created on 04/23/2026 22:47 using paint_kip.jar
* Plate Curves image file: 4J1S.jpg
.SUBCKT 4J1S P G2 G K ; LTSpice tetrode.asy pinout
* .SUBCKT 4J1S P G K G2 ; Koren Pentode Pspice pinout
+ PARAMS: MU=19.6 KG1=3256 KP=67.57 KVB=12 VCT=0.2 EX=1.512 KG2=4200 KNEE=11.76 KVC=2.056
+ KLAM=2.5E-8 KLAMG=6E-5 KNEE2=20 KNEX=30  KNK=-0.044 KNG=0.006 KNPL=50 KNSL=11 KNPR=120 KNSR=29
+ CCG=4P CGP=0.007P CCP=5P RGI=2000.0
* Vp_MAX=300 Ip_MAX=10 Vg_step=0.5 Vg_start=-1 Vg_count=11
* X_MIN=86 Y_MIN=139 X_SIZE=956 Y_SIZE=451 FSZ_X=1616 FSZ_Y=876 XYGrid=false
* Rp=1400 Vg_ac=20 P_max=2 Vg_qui=-3.5 Vp_qui=300
* UL=0.43 EG2=100 gridLevel2=n addKink=y isTanhKnee=y advSigmoid=n
RE21 21 0 1
.ENDS
716 点
607 ¥
发表于 2026-4-24 17:40 | 显示全部楼层
感谢壳爷的分享精神
GMT+8, 2026-7-27 08:03 , Processed in 0.579178 second(s), 19 queries , Gzip On, Redis On.
