- 899
- 980 小时
- 2026-10-11
- 50
- 1026304
- 809
- 899 点
- 713 ¥
- 2023-2-15
楼主 |
发表于 2026-2-2 16:27
显示全部楼层
The TPA3255 Power Amplifier is a power amplifier chip using class-d topology which is included in the large power class-d power amplifier category for the amp chip class, from the datasheet it can output up to hundreds of watts of power, in 4 channel mode it can output up to 150W of power per channel, so in total 600W, can also be used for 2 channel BTL 2x315W, or 2.1 channel 2x150W and 1x315W.
The TPA3255 is a powerful amplifier suitable for everything from subwoofers to tweeters. Its flat output makes it ideal for home audio applications. Assembly is not too difficult.
From this data, it does include the high power of the TPA3255 amplifier which can be supplied with a single voltage of 18-53.5VDC. will share for free its amplifier schematics as well as Gerber files, BoM, and CPL files. Where this DIY amplifier will use SMD components so it will be easier if you use PCBA or PCB Assembly services.
Power Amplifier TPA3255
To assemble SMD components is quite easy using PCBA Services, here I recommend using PCBA from JLCPCB. You simply register a JLCPCB account here $60 coupons for new customers. |
