[DIY制作] D类功放D1K时钟版 附文件
[复制链接] 查看: 4337|回复: 26
91
职业侠客 当前在线
871 点
689 ¥
发表于 2025-7-19 20:36 | 显示全部楼层
Hello guys, in this post I will share the PCB layout power amplifier Class-D D1K Clocked. Power Amplifier uses an external clock, using the CD4049 IC as a triangle signal generator. The following is a schematic image, this scheme was designed by Mr. Kartino Surodipo Master Class-D from Indonesia.
Power Amplifier Class-D D1K Clocked
You can download the schematic above as a PDF file, so you can see a clearer schematic image. Class-D D1K Clocked using External Clock from IC CD4049 as its triangle wave generator. IC CD4049 is very vital, use a good quality IC. so that the shape of a good triangle signal is flawless, if you use a bad IC CD4049, this will result in bad sound output too. Usually, there is a large amount of noise, and even worse, the amplifier cannot run, because the triangle wave does not come out of the CD4049 IC. to balance the PWM gate you can set the trimpot slope balance. and trimpot freq to set the PWM frequency.
And need to pay attention again to the 5V supply, the 5V supply must be balanced too, otherwise, we will have trouble setting the slope balance.
Power Supply 90VDC Symmetrical.
91
职业侠客 当前在线
871 点
689 ¥
 楼主| 发表于 2025-7-19 20:46 | 显示全部楼层
高清原理图
SCH_Schematic1_2025-07-19.zip (51.24 KB, 下载次数: 682)
91
职业侠客 当前在线
871 点
689 ¥
 楼主| 发表于 2025-7-19 20:50 | 显示全部楼层
打板文件
下载合并
Gerber_PCB3_2025-07-19.zip (296.89 KB, 下载次数: 654)
39 点
37 ¥
发表于 2025-7-19 21:05 | 显示全部楼层
感谢分享,看看
91
职业侠客 当前在线
871 点
689 ¥
 楼主| 发表于 2025-7-19 21:07 | 显示全部楼层
看图说话
410 点
363 ¥
发表于 2025-7-19 21:44 | 显示全部楼层
看看
114 点
112 ¥
发表于 2025-7-21 21:38 | 显示全部楼层
感谢分享
140
4069 点
2699 ¥
社区贡献 优秀设计
发表于 2025-7-22 09:08 | 显示全部楼层
三角波为什么要用方波经过RC产生,这种方式的‘三角波’是非线性的,如下图,
会导致脉冲宽度和输入信号不成比例,例如0.1V的输入信号的脉宽是1us,0.2V的脉宽是2.2us
49 点
47 ¥
发表于 2025-8-5 16:14 | 显示全部楼层
非常详细且技术性强
291 点
264 ¥
发表于 2025-8-5 18:02 | 显示全部楼层
感谢分享,看看
189 点
185 ¥
发表于 2025-10-13 16:04 | 显示全部楼层
这是个好东东,收了
68 点
66 ¥
发表于 2026-1-10 19:53 | 显示全部楼层
ok
687 点
661 ¥
发表于 2026-1-10 20:44 | 显示全部楼层
支持分享
194 点
123 ¥
发表于 2026-1-10 21:23 | 显示全部楼层
感谢分享!!
365 点
345 ¥
发表于 2026-1-12 10:34 | 显示全部楼层
电路有点复杂了,3个071及4049完全可以省去,反馈可以直接到311
41 点
39 ¥
发表于 2026-1-12 10:39 | 显示全部楼层
感谢分享,看看
129 点
105 ¥
发表于 2026-1-12 22:06 来自手机端 | 显示全部楼层
谢谢分享了
91
职业侠客 当前在线
871 点
689 ¥
 楼主| 发表于 2026-1-13 17:07 | 显示全部楼层
道路千万条  一只三极管也可以做音频放大
工兵
373 点
356 ¥
发表于 2026-1-19 08:34 | 显示全部楼层
感谢分享!!
112 点
102 ¥
发表于 2026-1-19 09:30 | 显示全部楼层
感谢分享,学习!!
GMT+8, 2026-9-1 14:31 , Processed in 0.210664 second(s), 10 queries , Gzip On, Redis On.
