- 3846
- 7440 小时
- 2024-5-7
- 120
- 12
- 176
- 3379
- 12
- 3846 点
- 2486 ¥
- 2004-3-26
高压悬浮/自举供电,设计者通常可能会忽略运放的共模输入范围。
例如运放同相输入是通过电阻接地GND,而Vcc和Vee则浮动供电。
假如浮动范围超过一定程度,例如Vee被自举到超过GND的电压,但此时同相输入端的电位是接地的,也就是说同相输入端电压反而低于Vee脚电压,此时运放工作是不正常的。此时就需要采取一些特别的措施或技巧
例如LM12 大电流运放的文档就有LM12的扩压电路,你会看到他的反馈很奇怪,同时反馈到同相和反相输入端。
The supply terminals of the LM12 swing both above and below ground at full output. Therefore, the input terminals must be bootstrapped to the output to keep them within the common-mode range. The R 1–R4 bridge does this. The bridge is unbalanced by R5 to set the gain near 30. Naturally,R4 and R 5 can be combined.
