- 2
- 17 小时
- 2019-12-31
- 40
- 864955
- 3
- 2 点
- 0 ¥
- 2019-7-23
请教个问题~~
CS43198 的 Filtering Options 部分介绍了几种滤波器模式,
For PCM/TDM mode, the following interpolation filtering options can be selected:
• Fast roll-off and slow roll-off interpolation filter options.
• In each option above, both low-latency and normal phase-compensation filtering options can be used.
• Nonoversampling (NOS) mode is provided, which minimizes the internal digital processing. Once NOS mode is set,
the settings on the above two options are ignored.
请问谁知道那个“normal phase-compensation filtering” 是怎么个原理啊?还有和“low-latency” 比较有什么特点呢?
谢谢。 |
