[音箱资料] 发现一个10寸单元大家看看如何?
[复制链接] 查看: 2784|回复: 3
281 点
209 ¥
发表于 2008-6-14 13:25 | 显示全部楼层
发现一个10寸单元做个三分频大家看看如何?
Electrical Data
Nominal impedance        Zn        8        ohm
Minimum impedance        Zmin        4.9        ohm
Maximum impedance        Zo        53.3        ohm
DC resistance        Re        3.4        ohm
Voice coil inductance         Le        4.3        mH
Capacitor in series with x ohm        Cc        22        uF
T-S Parameters
Resonance Frequency        fs        18.9        Hz
Mechanical Q factor        Qms        2.63
Electrical Q factor        Qes        0.18
Total Q factor        Qts        0.17
Force factor         Bl        17.5        Tm
Mechanical resistance        Rms        6.12        Kg/s
Moving mass        Mms        135.3        g
Suspension compliance        Cms        0.52        mm/N
Effective cone diameter        D        21.2        cm
Effective piston area         Sd        352        cm2
Equivalent volume         Vas        89.7        ltrs
Sensitivity (2.83V/1m)                88.4        dB
Ratio BL/√(Re)                112
Ratio fs/Qts        F        --
        Power handling
100h RMS noise test (IEC)        --        W
Long-term Max Power (IEC 18.3)        --        W
Max linear SPL (rms) @ power        --        dB/W
Short Term Max power (IEC 18.2)        --        W
Voice Coil and Magnet Parameters
Voice coil diameter        51        mm
Voice coil height        33        mm
Voice coil layers        4
Height of the gap        8        mm
Linear excursion +/-        --        mm
Max mech. excursion +/-        --        mm
Flux density of gap        1.04        mWb
Total useful flux        2.5        mWb
Diameter of magnet        147        mm
Height of magnet        35        mm
Weight of magnet        2.42        Kg
870 点
916 ¥
发表于 2008-6-14 13:40 | 显示全部楼层
243
什么都懂一点的杂家
9391 点
8647 ¥
DIY大赛冠军
发表于 2008-6-16 18:20 | 显示全部楼层
宝丽音
223 点
171 ¥
发表于 2008-6-17 01:02 | 显示全部楼层
这是个炮喇叭,不适合3分频
GMT+8, 2025-11-26 14:26 , Processed in 0.159849 second(s), 10 queries , Gzip On, Redis On.
