[DIY制作] 来了来了~~~797架构功放
[复制链接] 查看: 48692|回复: 239
31
953 点
894 ¥
 楼主| 发表于 2019-8-24 16:47 | 显示全部楼层
音频功率放大器设计手册第六版 audio_power_amplifier_design_6e,page227
The Folded-cascode VAS
The folded-cascode configuration shown in Figure 8.23 is not just another variation on the push-pull VAS driven by a single input stage. It is usually called the foldedcascode configuration, because Q4, Q5 are effectively cascoding the collectors of input stage Q2, Q3. The distinguishing characteristic of this configuration is that the two transistors Q4, Q5 are common base stages and their emitters are driven from the collectors of input stage Q2, Q3. Q1 is a cascode transistor for the collector of Q4 (sort of a cascode of a cascode); it is not an essential part of the folded-cascode concept. The current output of Q1 is bounced off the V-rail by the currentmirror Q6, Q7 and provides the lower part of the push-pull drive to the VAS stage Q5, Q7.
The really important point about this approach is that it is not a three-stage architecture; it is a two-stage architecture with input stage and VAS combined in one stage. The current variations in the input pair are passed unamplified to the VAS output by the folded-cascode transistors Q4, Q5, which give no current gain. These relatively small current variations have to do the best they can to generate a high voltage gain although subject to non-linear loading from the output stage.
This is bound to lead to a lack of overall open-loop gain. The only obvious way to increase it is to raise the impedance seen at this point by putting a unitygain buffer between the input/VAS and the output stage. This approach can work well in opamps, but there seems to be little advantage in a power amplifier.
We are already using more transistors than in a threestage Blameless amplifier. Another objection is that there is no obvious way to apply the Miller dominant pole compensation that is so very useful in linearising a conventional VAS.
While the folded-cascode configuration has been used extensively in opamps (in opamp usage the two resistors R1, R2 are normally replaced by constantcurrent sources), it has only rarely been applied to audio power amplifiers, and I have no practical experience with it.
I am not sure if any commercial amplifiers have been built using the folded-cascode structure, but at least one such design has been published for amateur construction by Michael Bittner and the circuit values here are based on that.
31
953 点
894 ¥
 楼主| 发表于 2019-8-24 16:57 | 显示全部楼层
接着我上diyaudio找了这个引用的Michael Bittner 的贴。
https://www.diyaudio.com/forums/solid-state/52388-ultrafast-nocap-classab.html
这货也是贴图贴一半的货,他用了一个led作偏置电压,但少画了个电阻或者恒流源。
这线路为了不用补偿电容,在输入级串了两个33R电阻降低跨导,整个线路开环增益比我现在的线路还要低,然后第二级的电流镜设计的也远没有ADI的工程师精妙,后面就是单位增益缓冲器。
总的来说和我现在的架构没啥两样。。。
1121 点
1055 ¥
发表于 2019-8-24 17:39 | 显示全部楼层
https://www.diyaudio.com/forums/solid-state/52 ...
过去的理解,韩国的晶体管是低档的,日本的中档,其中有高档的,美国的高档比较多。
所以我极少使用韩国晶体管。明显,韩国货便宜,国产功放使用最多。
1121 点
1055 ¥
发表于 2019-8-24 17:42 | 显示全部楼层
该图很多地线,接地点,很容易有电流声,即使处理的好。也存在其他负面的影响。
1121 点
1055 ¥
发表于 2019-8-24 17:59 | 显示全部楼层
回到你那个图,Q6Q7的发射极电压也是浮动的,有没有问题还不好说,集成电路里面做得到,外面的电子元件就未必能做好
Q9Q10R6,还是改回797里面的结构好,Q8可能影响该节点电压
31
953 点
894 ¥
 楼主| 发表于 2019-8-24 18:02 来自手机端 | 显示全部楼层
所以我极少使用韩 ...
我除了两个大管其他都是用的国产管
1121 点
1055 ¥
发表于 2019-8-24 18:17 | 显示全部楼层
把C5左边的接线断开,C5并联10K电阻,再通过10K串联接直流稳压电源,电压0至+-30伏,接负载测试,就很容易找到内阻大的原因。负载用100、1K、10K
这个方法就是改测交流变为测直流,可以直接发现哪个管还是电源出问题,或是前面的问题
31
953 点
894 ¥
 楼主| 发表于 2019-8-24 18:19 来自手机端 | 显示全部楼层
小功放 发表于 2019-8-24 18:17
把C5左边的接线断开,C5并联10K电阻,再通过10K串联接直流稳压电源,电压0至+-30伏,接负载测试,就很容易 ...
记下了
31
953 点
894 ¥
 楼主| 发表于 2019-8-26 14:16 来自手机端 | 显示全部楼层
谢谢大家帮忙,问题解决了,问题的答案是。。。并没有问题。
周五应该是哪个表棒的地线接触不好导致的,今天我两块板子从新接线都试了一切正常。收工了!过会儿整理下资料一并上传,谢谢大家关注。
31
953 点
894 ¥
超低失真之梦 发表于 2019-8-23 18:57
倒置达林顿 那个100欧姆电阻,拆下来测量下,是不是100, 大功率管坏了?假货?
没有错误的话不可能 ...
31
953 点
894 ¥
 楼主| 发表于 2019-8-26 14:17 来自手机端 | 显示全部楼层
wsy888wsy 发表于 2019-8-24 11:56
极点:如果一个功放中有2个独立的模块,因为每个独立的模块固定的谐振频率不同,会形成2个谐振点 ...
3662 点
3587 ¥
发表于 2019-8-26 14:45 | 显示全部楼层
周五应该是哪个表棒的地线接触不好导致的, ...
   就说吗,电路从原理分析不可能的事。
31
953 点
894 ¥
 楼主| 发表于 2019-8-26 14:51 来自手机端 | 显示全部楼层
这是最终的测试波形,补偿电容两个100p
31
953 点
894 ¥
 楼主| 发表于 2019-8-26 15:03 来自手机端 | 显示全部楼层
超低失真之梦 发表于 2019-8-26 14:45
就说吗,电路从原理分析不可能的事。
大师我现在手上只有一台笔记本,怎么能测试功放的指标?
3662 点
3587 ¥
发表于 2019-8-26 15:06 | 显示全部楼层
别大师,     可以用rmaa软件通过笔记本声卡测试的。你论坛搜索rmaa 有帖子教学。
31
953 点
894 ¥
 楼主| 发表于 2019-8-26 17:20 来自手机端 | 显示全部楼层
ok我去学习下
31
953 点
894 ¥
 楼主| 发表于 2019-8-26 18:54 | 显示全部楼层
附件是这一板的定稿参数及图纸。
797AMP_V0.1.zip (290.92 KB, 下载次数: 264)
325
5800 点
5626 ¥
发表于 2019-8-26 20:25 来自手机端 | 显示全部楼层
好功力
31
953 点
894 ¥
 楼主| 发表于 2019-8-26 21:44 来自手机端 | 显示全部楼层
q1688 发表于 2019-8-26 20:25
好功力
不行不行,瞎搞搞的
侠之大者 当前在线
1663 点
1609 ¥
发表于 2019-8-26 21:49 | 显示全部楼层
觉得Q8和Q13可以合并,再把Q2、Q19的电流调一下,使Q11、Q13的电流平衡。Q9、Q10还是单独的偏置为好。
用楼主以前的仿真文件改的:
