- 1971
- 1382 小时
- 2023-4-10
- 70
- 4
- 23793
- 2565
- 4
- 1971 点
- 1844 ¥
- 2007-6-19
1楼。I have always been a fan of quasi complementary output stages: they are inexpensive to make, they are very rugged, and you don't have to match them.
so I was quite happy when I saw NAP140 PCBs available here.
However, I don't particularly like the circuit. In particular, it uses too many active load and I want to use N-channel mosfets.
so I simulated a few of the circuits and here is what I learned.
here is the schematic. I typically design my amps to run on 4-ohm load, and on 1Vp input. Here, the amp is driven by a 1Vp 20khz sine wave.
翻译:我一直是范准互补输出阶段:他们是廉价作出,他们是非常崎岖的,你不用,以配合他们。
所以我很乐意当我看到nap140多氯联苯可在这里。
不过,我并不特别喜欢的电路。特别是,它使用了太多的积极负荷,我要使用的N沟道MOSFET 。
因此,我模拟的几个电路和这里是我的经验教训。
这里是示意图。 i通常设计我的安培上运行4 -欧姆的负载,以及1vp投入。在这里,安培是驱动一1vp 20 kHz正弦波。
2楼。here is the output waveform.
you see clearly massive cross-over distortion on the negative side. Not good.
这里是输出波形。
你清楚地看到,大规模的跨超过失真在消极的方面。也不是好事。
3楼。how about its frequency response?
here it is.
Something is seriously wrong in the 7-800Khz range. the amp is obviously self-oscillating there.
又如何,其频率响应?
在这里,这是。
一些是严重错误,在7 800khz范围。该安培,显然是自振荡。
5楼。does that mean it is hopeless?
not exactly.
some easy fixes, as proposed in this version of NAP140.
1) input resistor: 100K is simply too much.
2) I added R43/R44 to just balance out the effect of unmatched input transistors. 11 - 47ohm is typical. Higher numbers also reduce open loop gain, something I like.
3) R31: that was an obvious mistake in the original schematic. corrected here.
4) I also added R29, again to reduce open loop gain and to make the amp more linear open loop.
5) R33/47/51 changed to a much lower number to increase the idle current on the drivers. They now idle about 30ma - just about right.
other changes are added to address stability.
As you can see, there is no more cross-over distortion, even at 100ma idle current.
这是否意味着它是无可救药的?
不完全。
一些容易修复,建议在这个版本的nap140 。
1 )输入电阻: 100K的简直是太多。
2 )我补充说: r43/r44公正平衡的影响无与伦比的投入晶体管。 11 -4 7ohm,是典型的。较高的数字也可以减少开环增益,一些我喜欢。
3 ) r31 :这是一个明显的错误,在原来的示意图。纠正在这里。
4 )我也补充说: r29 ,再次以减少开环增益,并作出安培更多的线性开环。
5 ) r33/47/51改变,以低得多的数目增加闲置目前对司机。他们现在闲置约三〇毫安-只需约的权利。
其他的变化,加上地址稳定。
你可以看到,有没有更多的跨超过失真,甚至在一百毫安闲置电流。
6楼。this is the frequency response. Not perfect but much better.
这是频率响应。并非十全十美,但好得多。
7楼。here is the same amp, with IRF540 as output devices and Vgs multiplier.
I added two gate stoppers and change some values, all highlighted.
这里是相同的安培, irf540作为输出设备和vgs乘数。
我已将二门塞子和改变一些价值观,都突出。 |
