- 17387
- 24854 小时
- 2024-4-18
- 150
- 2
版主
当前离线
脑放进行时
- 3986
- 18055
- 2
- 17387 点
- 15124 ¥
- 2005-4-20
发表于 2019-4-18 11:09
来自手机端
显示全部楼层
以官方手册说法为准,与手册相悖的传说不可信。
引文如下(参考百度翻译)
MUTE MODE
By placing a logic-high voltage on the mute pins, the signal
going into the amplifiers will be muted. If the mute pins are
left floating or connected to a logic-low voltage, the amplifiers will be in a non-muted state. There are two mute pins,
one for each amplifier, so that one channel can be muted
without muting the other if the application requires such a
configuration. Refer to the Typical Performance Characteristics section for curves concerning Mute Attenuation vs
Mute Pin Voltage.
静音模式
通过在静音管脚上放置逻辑高电压,信号进入放大器将被静音。
如果静音管脚是悬空或连接到逻辑低电压,放大器将处于非静音状态。
有两个静音管脚,每个放大器一个,这样如果需要可以分别控制任一个通道单独静音。
相关参考静音衰减与静音管脚电压图表。
STANDBY MODE
The standby mode of the LM1876 allows the user to drastically reduce power consumption when the amplifiers are
idle. By placing a logic-high voltage on the standby pins, the
amplifiers will go into Standby Mode. In this mode, the current drawn from the VCC supply is typically less than 10 μA
total for both amplifiers. The current drawn from the VEE supply is typically 4.2 mA. Clearly, there is a significant reduction
in idle power consumption when using the standby mode.
There are two Standby pins, so that one channel can be put
in standby mode without putting the other amplifier in
standby if the application requires such flexibility. Refer to
curves showing Supply Current vs. Standby Pin Voltage for
both supplies.
待机模式
LM1876的待机模式允许用户在放大器空闲的通过在待机引脚上放置逻辑高电压,放大器将进入待机模式。
在这种模式下,VCC电源的电流通常小于10微安。两个放大器的合计。VEE电源的电流通常为4.2 mA。
显然,待机模式时显著减少空闲功耗。
有两个待机控制管脚,这样就可以设置其中一个声道在待机模式下,另一个声道不进行待机,可以灵活的应用。
参照典型性能特征部分显示电源电流与备用引脚正负电压的电流曲线。 |
