- 1179
- 2353 小时
- 2022-4-23
- 70
- 577648
- 1089
- 1179 点
- 958 ¥
- 2013-3-26
楼主 |
发表于 2019-1-21 21:25
显示全部楼层
还好,LDO支持低ESR电容。输入是CLC隔离数字干扰,挻有效的。
唉
Output Capacitor
To ensure the stability of the SPX1117, an
output capacitor of at least 2.2μF (tantalum or
ceramic) or 10μF (aluminum) is required. The
value may change based on the application
requirements of the output load or temperature
range. The value of ESR can vary based on the
type of capacitor used in the applications to
guarantee stability. The recommended value
for ESR is 0.5Ω or less. A larger value of
output capacitance (up to 100μF) can improve
the load transient response.
为了提高瞬态响应,说要100uF以上,我就用了220UF。
其实远离输出的地方还有220UF的高分子钽,为了低ESR而不影响稳压。
除了电容,难道不能说点别的吗?比如那块电池多少伏。。..8.4V的。
