- 244
- 929 小时
- 2023-7-5
- 50
- 834496
- 234
- 244 点
- 218 ¥
- 2017-6-28
楼主 |
发表于 2018-3-25 20:01
显示全部楼层
I've noticed a tiny class D amps on taobao and ebay is getting popular, however, all of them had external SMPS and usually awful industrial/LED or power brick for a laptop. I like a challenge, so I decided to design the same size amp but with a good quality audio grade SMPS onboard. What do you think, how high current should provide audio-amp SMPS to get 2x115W@20Hz@4ohm? Let's calculate a little. 4ohm/2ch =2ohm load equivalent, 20Hz means 25mS peaks of current, so for 30.5V rails, we need >15A (or a lot of uF capacitors but we have no room for that), or about 500W SMPS output power for short terms. I want to show you typical external SMPS box what I saw on taobao together with the second box as class D amp "2x300W", 423RMB for both. The SMPS is probably LED or telecom type for 48VDC and 7.5A max current. Now you can calculate without my help the real power of such amp+SMPS, and it is far-far from 2x300W ;) Yes, it is funny but 20Hz power expected only 28W, 11x times less than promised + safety problems and for sure EMC too.. Variant with power-brick for 55RMB will be even worse. So, the power supply of the audio amp is same important as the amp itself.
我已经注意到在淘宝上有一个小D类放大器,eBay越来越受欢迎,但是,他们都有外部SMPS,通常用于笔记本电脑的工业/ LED或功率砖很糟糕。我喜欢挑战,所以我决定设计相同尺寸的功放,但是在板上安装了高质量的音频级SMPS。你怎么看,多大的电流应该提供音频放大器SMPS以获得2x115W @ 20Hz @ 4ohm?让我们计算一下。 4ohm / 2ch = 2ohm负载等效,20Hz表示25mS峰值电流,因此对于30.5V电压轨,我们需要大于15A(或许多uF电容,但我们没有空间),或短时间大约500W SMPS输出功率。我想向您展示我在淘宝上看到的典型外部SMPS盒,以及第二个盒子的D类放大器“2x300W”,两者均为423RMB。 SMPS可能是LED或电信类型,用于48VDC和7.5A最大电流。现在你可以在没有我帮忙的情况下计算这种放大器+ SMPS的实际功率,而且它离2×300W差不多;)是的,这很有趣,但20Hz功率预计只有28W,比所承诺的+安全问题低11倍,太多了。55元的电力砖变种会更糟。所以,音频放大器的电源与放大器本身一样重要。
2018-03-25_19-29-39.jpg |
