- 361
- 324 小时
- 2022-12-25
- 50
- 295725
- 348
- 361 点
- 326 ¥
- 2011-2-23
楼主 |
发表于 2018-1-7 19:19
显示全部楼层
二、Single Ended Class A
单端A类放大
Only one approach is available for linear performance from such a simple circuit: Single-Ended Class A. It was the topology in the earliest use of gain devices (tubes, of course), but has not been widely employed in the output stages of solid state power amplifiers due to its
Push-pull circuits have higher efficiency, and they also have an advantage in being able to source current in excess of the idle, or bias, current, by dropping into a lower class of operation. A Push-Pull Class A amplifier idling at a 1 amp bias current can deliver 2 amp peaks before leaving Class A, and can deliver still higher currents considered as a Class AB amplifier, where one half of the amplifier experiences cutoff, and does not carry the signal for a portion of the waveform. By contrast, Single-Ended Class A amplifiers cannot linearly deliver current beyond their bias point, and they generally must dissipate at idle more than 4 times their rated output. Typical efficiency is about 20% maximum.
只有一种方法是既可以获得线性性能又是最简单的电路:单端A类放大.它是电路设计最早使用的放大电路,但单端A类放大没有被广泛采用,因为相对于单端的方法推挽电路具有更高的效率。推挽式的设计有他们的优点,就是效率高,推挽式放大可设计成AB类放大器。与此相反,单端A类放大器效率低,有空闲电流流掉,其典型效率只有约20%。
This tremendous inefficiency alone explains why Single-Ended Class A has received limited attention, although careful consideration of possible circuits reveals that efficiencies approaching 50% are possible. In addition, there are ways in which a Single-Ended Class A amplifier can be operated as a push-pull device beyond its bias point, the assumption being that push-pull performance is preferable to clipping. Pass Labs has received one patent and has an application for another reflecting new developments in this area.
这种巨大的效率低下解释了为什么单端A类获得的关注很有限,虽然仔细考虑可能的电路,效率接近50%是可能的。此外,我们研究了一种新方法,将一个单端A类放大的设计在一个推挽电路中,作为它的一部分,我们的实验室已获得一个专利,并有另一个更新的应用设计在这方面有新的发展。
