dx
329 点
301 ¥
 楼主| 发表于 2018-1-3 20:47 | 显示全部楼层
雅俊主板电源部分有特色,场馆恒流源,正负电源稳定性非常好。 9116 的控制电路很不同于厂家维修手册的标准电路,外加多重隔离措施,所以信噪比也很高,再用上高一级的6116,就更上一层楼了。
dx
329 点
301 ¥
 楼主| 发表于 2018-1-3 20:48 | 显示全部楼层
我做过金嗓子,电源电路比起来还没有雅俊高级。
dx
329 点
301 ¥
 楼主| 发表于 2018-1-4 21:25 | 显示全部楼层
mas6116 参数:MAS6116
Stereo Digital Volume Control
• Signal Voltage up to ± 18V
• Two Independent Channels
• Use of Differential DACs Possible
• Serial Control Registers
DESCRIPTION
MAS6116 is a stereo volume control for audio
systems, which require high output voltages (AC3).
It has serial interface, which controls two audio
channels. Simple serial interface allows
microcontroller to control many MAS6116 chips on
the same PCB board. “Clicking” between gain
changes is eliminated by changing gain only when
zero crossing has been detected in the input signal.
MAS6116 also features a peak detection circuitry
that allows easy monitoring of the output signal.
MAS6116 has also a set of “instant gain change”
instructions that allow fast gain switching. The use
of external operational amplifier provides flexibility
for the operating voltage, signal swing, noise floor
and cost optimization.
FEATURES APPLICATION
• Zero Cross Detection for Gain Changes
• Gain Range +15.5db…-111.5dB
• 0.5 dB Gain Step Size
• Mute Pin
• Power On/Off Transient Suppression
• Signal Peak Level Comparator with Adjustable
Reference
• Independent Writing to Both Channels
• Instant Gain Change Function for Fast Gain
Switching
• XMUTE Using the Zero Cross and Timeout
Functions
• Write Operation Status Register
• High End Audio Systems
• Multi-channel Audio Systems
dx
329 点
301 ¥
 楼主| 发表于 2018-1-7 16:58 | 显示全部楼层
高端大气上档次。
dx
329 点
301 ¥
 楼主| 发表于 2018-1-9 06:43 | 显示全部楼层
现在调试到的是100级音量,比较快了。
禁言警告级 当前离线
Rank: 1
-3 点
15 ¥
发表于 2018-1-9 08:30 | 显示全部楼层
非常不错
dx
329 点
301 ¥
 楼主| 发表于 2018-1-9 22:11 来自手机端 | 显示全部楼层
1DB
dx
329 点
301 ¥
 楼主| 发表于 2018-1-10 19:46 | 显示全部楼层
1DB/步
232 点
212 ¥
发表于 2018-1-12 10:51 | 显示全部楼层
数字流也可以调节音量?有点理解不过来。哈哈
dx
329 点
301 ¥
 楼主| 发表于 2018-1-13 09:48 | 显示全部楼层
数字程序控制的是电阻阵列,即运放反馈电阻,阻值切换。
dx
329 点
301 ¥
 楼主| 发表于 2018-1-13 09:54 | 显示全部楼层
芯片手册图
dx
329 点
301 ¥
 楼主| 发表于 2018-1-15 20:34 | 显示全部楼层
高级的马兰士也用6116芯片
dx
329 点
301 ¥
 楼主| 发表于 2018-1-20 20:41 来自手机端 | 显示全部楼层
芯片现在也少卖。
dx
329 点
301 ¥
 楼主| 发表于 2018-1-24 18:25 来自手机端 | 显示全部楼层
电路很有特色。
356 点
278 ¥
发表于 2018-1-24 19:41 | 显示全部楼层
1751 点
1396 ¥
发表于 2018-1-26 11:55 | 显示全部楼层
这货不就是WM8816的翻版嘛。
而且性能还不如WM8816,单端输入THD比WM8816高多了
dx
329 点
301 ¥
 楼主| 发表于 2018-1-26 17:29 来自手机端 | 显示全部楼层
8816只出了一代,有吱噪音。MAS9116是一代与8816差不多,6116是9116的升级版。没有吱声。
dx
329 点
301 ¥
 楼主| 发表于 2018-3-17 11:31 | 显示全部楼层
对板子做测试,输入方波1KHZ,看它的响应
dx
329 点
301 ¥
响应
dx
329 点
301 ¥
 楼主| 发表于 2018-3-17 11:33 | 显示全部楼层
1KH正弦波输入也测试下
