- 444
- 367 小时
- 2024-5-1
- 50
- 1
- 359
- 282
- 1
- 444 点
- 11 ¥
- 2004-4-13
楼主 |
发表于 2005-5-9 16:03
显示全部楼层
仿1sc的这个在1.5K左右的谷是低音单元固有的
以下是引用维卡亚在2005-5-9 11:02:00的发言:
...看了你的仿PROAC的曲线.不是很满意呀.建议有时间改一下分频.
下面是一位老外的话:
The overall response from the T14RCY is not the most beautiful around. But the sound is much better than it appears from the graph above. The ear is highly sensitive to bumps, where dips can very hard to detect. The intrinsic dip at approx. 1.7 kHz from the T14 is derived from resonance in the rubber surround. It can be dampened by placing self-adhesive foam strips on the rubber close to the membrane, but then the crossover needs further fine-tuning, so better leave it here.
原文见这里:
http://home1.stofanet.dk/troels.gravesen/index_b/1S_Clone.htm
虽不能完全认同,但应该还是有一些道理的。 |
