- 191
- 2682 小时
- 2021-6-2
- 50
- 782081
- 807
- 191 点
- 127 ¥
- 2015-1-12
Comments: This is a midrange specific driver. It is relatively sensitive at just under 90dB, but it's 4 ohm impedance is responsible for this. This uses the Revelator slit-cone design to control breakup and present a respectably flat and extended response. On the other hand, the motor construction lacks the copper faraday rings of it's larger siblings and has higher nonlinear distortion as a result. Still it's not too bad, and easily usable as a very wide range mid driver. Value is extemely low - It's a nice midrange but I'd expect more for that price. Tested February 2007
译文:点评:这是一个中档专用驱动器。它是相对敏感的只有90dB,但它是4欧姆的阻抗是负责这。使用启示者缝锥的设计来控制破碎和一个体面的平和扩展的响应。另一方面,电机结构缺乏铜法拉第环的较大的兄弟姐妹,并具有较高的非线性畸变的结果。还不是太坏,且容易使用的是很宽的范围中的驱动程序。值是非常低-这是一个不错的中档但我希望这个价格更。测试二月2007
别夸我英语水平高,百度翻译可以满足坛友好奇心! |
