- 3558
- 2988 小时
- 2025-5-30
- 120
- 3
- 8411
- 3222
- 3
- 3558 点
- 1885 ¥
- 2006-4-5
Let's see... We have an op-amp, a couple of transistors, a voltage reference, and a few resistors. Can we build a linear regulator from these individual components? Yes, we can!
看看。。假如我们有一个运放,一些电阻,一个参考电压源以及一些晶体管,我们是否可以制作一个线性稳压电源?答案是肯定的!
Why DIY a Regulator?
Before monolithic IC regulators became popular, people made linear regulators from discrete components and maybe a general-purpose IC or two. I'll call them DIY regulators, lacking a better term.
为什么要做稳压电源?
在单片集成电路流行前,人们用分离元件制作稳压电源,或许就类似单或多功能的IC。我会称他们是DIY稳压电源,因为没有一个专业的称谓。
Like the μA741 IC op-amp did to small discrete amplifiers in the late 1960's, the invention of the 3-terminal fixed IC regulator a few years later started pushing out DIY regulators and fully discrete regulators. These IC regulators are easy to apply, take up little board space, and have quite good performance. The secondary effects of these facts are that 3-terminal regulators like the LM317 are made by several manufacturers, and you can get them for as little as about 50 cents in single quantities. And if you want to spend a little bit of money to get even better performance, there are many improved regulators on the market. So why would one want to return to the days where people made their own linear regulators from generic parts?
就象741运放在60年代干掉分离放大器一样,几年后发明的3端稳压IC开始排挤分离元件稳压电源和DIY稳压电源的市场。这些IC使用简便,占用印板面积小,并且有非常不错的性能。第二个重要的因素是这些3端稳压比如LM317被许多厂家制造以至你可以花50美分在零售市场取得一个。如果你想多花点钱得到性能更好的,市场上有许多改进的集成稳压可以买到。所以谁还愿意回到用分离元件自己制作稳压电源的年代?
The main problem with the improved IC linear regulators on the market is that they have nonstandard pinouts and they can be fairly expensive. Consider the Linear Technology LT1581 high-current high-speed LDO regulator: it's a 7-pin TO-220 type package and it costs about $13 for single units. For $13, you can buy a pretty good collection of parts. If you can afford the board space the DIY approach takes up, you can often equal or better the performance of monolithic IC regulators.
市场上的那些改进的线性稳压IC的最大的问题是他们的引脚排列并非规则而且价格有些贵。不如线性公司的LT1581高速大电流LDO稳压电源:他是个7脚TO-220封装的元件,价格是每个13美元。而13美元你可以买到很多高级的零件了。如果不在乎印板面积,DIY可以做出接近IC或更好性能的的产品。
This article follows the history of a popular series of DIY linear regulators. Starting from initial concepts basically idential to the archetype block diagram above, this particular thread through history will wind up in a very sophisticated design. Because this final design developed piecemeal over the course of two decades, that's how I'll show it. I think showing the steps this series of designs went through aids understanding of the final design.
下面的文章记录了一组流行的DIY线性稳压电源的发展历史。从上面方块图原理所示发展起来,这个特定的设计思路已经经过了历史的考验。最终的版本花了20年时间来推翻了最初的时间,这就是我写出来的原因。我想显示这个系列的发展轨迹来让人们理解最终的设计。
We will follow the thread through the pages of the journal The Audio Amateur, the forerunner of audioXpress. audioXpress offers a complete catalog of back issues going back to 1970, so that's how I followed the history. (Most of the back issues are still available in printed form; a few years in the 1970s are sold out now and are only available on their 1970's reprint CD.) My purpose here is not to duplicate this material, but to summarize it and serve as a guide to it. If you want the full details of these designs, I recommend that you get the issues I reference. Many of these articles have a lot of information in them that I am glossing over here.
我们可以顺着音响杂志先驱The Audio Amateur的线索。audioXpress提供了追朔至70年代的所有目录,这是我追随历史的依据。(大部分历史目录在印刷物上;部分70年代现在有出售并且仅在70年代重新出版的CD上)我现在的观点不是简单地复制他们,而是总结他们并当一个向导使用。如果你想得到我提到的设计的详细的资料,我建议你买一本出版物。我在这里做解释的的文章在出版物里有许多重要的信息。
How Does a Series Linear Regulator Work?
The archetype block diagram above is called a series linear regulator, because the pass transistor is in series between the input and output. This type of regulator is based on a simple idea: you can control the voltage at the output leg of the transistor by manipulating the voltage at the base. Let's study the archetype design above.
线性稳压电源如何工作?上面的原始方块图称为线性稳压电源,因为调整三极管是串联在输入和输出中间的。这种稳压电源是基于一个简单的观点:你可以通过控制三极管的基极电压的方法来控制三极管输出脚的电压。让我们来学习原型的原理。
Connected to one input of the op-amp (called the error amp) is the voltage reference, VREF. You can make voltage references in many different ways, so the technology used isn't important at this point. A good reference puts out a fixed voltage under varying conditions, and you can get versions that put out any of several standard voltages.
连接op-amp(称为误差放大器)的一个输入脚的是参考电压,VREF。你可以通过许多不同的方法来取得参考电压,这个不在本文重点讨论范围。一个好的参考源可以在外部变化的条件下给出固定的电压参考,你可以使用发表过的任何标准电压源的版本。
Connected to the other input of the error amp is the midpoint of a voltage divider. We'll come back to this later.
连接误差放大器另一个输入点的是一个电压分压器的中点电压。稍后我们再来讨论。
An op-amp tries to make its two input voltages equal by adjusting its output voltage. In the diagram, the output of the error amp is connected to the base of an NPN transistor: when the error amp drives current into this transistor's base, it allows current to flow from collector to emitter, and that transistor in turn pulls current from the base of the pass transistor. This arrangement lets an op-amp capable of driving a few tens of milliamps control an amp or so of current across the pass transistor.
一个op-amp通过调节输出电压的方式来使两个输入端保持平衡。在这个图里,误差放大器的输出端连接到了一个NPN三极管的基极上:当误差放大器输出电流到了三极管的基极上,三极管允许电流从集电极向发射极流动,这个传输三极管工作时就是就是从基极吸取电流的过程。这样的安排可以让一个运放有几十毫安的驱动能力来控制一个放大器或者控制调整管的电流。
Now comes the neat bit. Let's say you have a 5V reference and the voltage divider is set up to divide the voltage from VOUT to GND by 4. Since the op-amp tries to make its two inputs equal and one input (the voltage reference) stays constant, it will adjust its output voltage until 5V appears at the midpoint of the divider. Since it's a divide-by-4 voltage divider, VOUT goes to 20V and it stays there because it's a real-time system, constantly adjusting to changing conditions.
现在详细讨论,比如你有一个5V的参考电压以及,一个从VOUT到GND分压比为4的分压网络。因为运放总是要保持两个输入端的平衡,而其中的一个是保持不变的(参考电压),所以,他会调节自己的输出电压一直到分压电路出现5V为止。由于分压比为4,所以最终的输出电压将保持在20V,因为这是一个实时的系统,会对变化的状况保持调节。
Voilá, you have a series linear regulator.
庆贺,你有了一个串联稳压电源了。
(If you want to read more about the operation of linear regulators, I recommend reading the AN-1148 app note I reference above.)
(如果你想阅读线性稳压电源更多的信息,我建议你阅读我提到的the AN-1148 app note)
Now, this simple design isn't perfect. The error amp can only slew so fast, the voltage reference will have some error, the output of the regulator has an effective impedance resulting in current-modulated voltage drops, and all of the components in question will drift to some extent as the temperature changes. Furthermore, all of the components in the regulator generate some noise, and this gets worse as temperature rises.
然而,这个简单的设计并非完美。误差放大器只会快速摇摆,参考电压也会有误差,稳压电源输出阻抗高导致电流调制方式的电压失落。而且所有的部件都不同程度的有温度漂移现象。此外,所有的部件都有噪音产生,而且随着温度上升而恶化。
Sophistication Begins: The Sulzer Regulator
In the 2/1980 issue of The Audio Amateur Mike Sulzer published this regulator design: |
