[音箱资料] ATC限量型号
[复制链接] 查看: 4327|回复: 13
56 点
4 ¥
发表于 2007-12-10 10:30 | 显示全部楼层
56 点
4 ¥
 楼主| 发表于 2007-12-10 10:33 | 显示全部楼层
ATC SM-150s Soft Dome Mid
ATC Super Linear 375mm Bass driver
Massive hand made motor assembly
Wide dispersion for perfect imaging
Cabinet designed to eliminate edge diffraction and internal resonance.
Original owner, lifetime guarantee.
Any veneer to order.
a lifetime guarantee
Specs
Drivers HF 25mm: Neodynium, Mid ATC Soft Dome, LF 375 SL
Frequency Response: (±2dB) 60Hk-17kHz (± 6dB) 25Hz-22kHz
Matched response: ± 0.5dB
Dispersion: +/- 80° Coherent Horizontal +/- 10Coherent Vertical
Crossover Frequencies: 380Hz and 3.5kHz
Sensitivity: 91dB@1w@1 metre
Max SPL: 117dB
Suitable amplifiers: 100- 1500 watts
Connectors; Tri wired terminal posts
Cabinet Dimensions: H 1315 W 650 D 290
Weight: 82kg
56 点
4 ¥
 楼主| 发表于 2007-12-10 10:34 | 显示全部楼层
Class A/B 150 watts per channel output stage
Fully discreet ultra low noise pre-amp circuitry
Massive power supply
Line level Sub woofer output
Addition pre out for driving second power amplifier
Fully guaranteed for 6 years
Specs
Output Power into 8Ω: 150W
Input sensitivity: 350mV
Input Impedance: 22k Ω
Frequency response: 5Hz-200kHz +/- 0.1dB
Signal to noise ratio: 100dB
Crosstalk: Better than 90dB
T.H.D.: -90dB/0.0032%
31
3569 点
3118 ¥
发表于 2007-12-10 10:40 | 显示全部楼层
这喇叭漂亮,特别喜欢那个馒头中音.
128
3799 点
3381 ¥
发表于 2007-12-10 10:44 | 显示全部楼层
得几十万吧?
450 点
450 ¥
发表于 2007-12-10 10:54 | 显示全部楼层
4817 点
4709 ¥
发表于 2007-12-10 16:53 | 显示全部楼层
漂亮:  有详细箱体图纸及分频资料的话,真TMD想DIY一对,用作以后DIY的参考
2753 点
2609 ¥
发表于 2007-12-10 19:17 | 显示全部楼层
和世霸旗舰一样:扁箱体!
2753 点
2609 ¥
发表于 2007-12-10 19:22 | 显示全部楼层
有利低频共鸣
不利中高频扩散
510
1080 点
650 ¥
发表于 2007-12-10 19:30 | 显示全部楼层
恶夜狂飚
1643 点
1643 ¥
发表于 2007-12-10 21:49 | 显示全部楼层
1294 点
1075 ¥
发表于 2007-12-11 21:56 | 显示全部楼层
外形越搞越怪了!好像B&W的也是,像下水道.
473 点
203 ¥
发表于 2007-12-12 01:30 | 显示全部楼层
真牛!!
4817 点
4709 ¥
发表于 2007-12-12 11:23 | 显示全部楼层
回复 #9 344ms 的帖子
恰好相反,偶到认为这种弧型面板更有利于中高频扩散,而且喇叭单元的参数本来就是在大障板上测得的
GMT+8, 2025-11-26 09:34 , Processed in 0.181700 second(s), 22 queries , Gzip On, Redis On.
