- 3516
- 14878 小时
- 2025-4-17
- 100
罗宾汉
当前离线
- 238600
- 3631
- 3516 点
- 3434 ¥
- 2010-9-9
对比过两种所谓DXD的文件,分别是2L的24bit和某网站压制的32bit浮点DXD,可以看到后者的精度还是24bit而不是32bit,再看后面幅值的分析,显然往下做了相应调整,除此之外看不出有什么惊异之处。
要说播放起来有什么区别,反正浮点的我的电脑跑都跑不动……- $ sox -V 2L-056_04.wav -n stat
- sox: SoX v14.4.1
- sox INFO formats: detected file format type `wav'
- Input File : '2L-056_04.wav'
- Channels : 2
- Sample Rate : 352800
- Precision : 24-bit
- Duration : 00:03:24.41 = 72117024 samples ~ 15331 CDDA sectors
- File Size : 433M
- Bit Rate : 16.9M
- Sample Encoding: 24-bit Signed Integer PCM
- Endian Type : little
- Reverse Nibbles: no
- Reverse Bits : no
- Output File : '' (null)
- Channels : 2
- sox INFO sox: effects chain: input 352800Hz 2 channels
- sox INFO sox: effects chain: stat 352800Hz 2 channels
- sox INFO sox: effects chain: output 352800Hz 2 channels
- Samples read: 144234048
- Length (seconds): 204.413333
- Scaled by: 2147483647.0
- Maximum amplitude: 0.822419
- Minimum amplitude: -0.889753
- Midline amplitude: -0.033667
- Mean norm: 0.049062
- Mean amplitude: -0.000042
- RMS amplitude: 0.072956
- Maximum delta: 1.003368
- Minimum delta: 0.000000
- Mean delta: 0.063978
- RMS delta: 0.094750
- Rough frequency: 72923
- Volume adjustment: 1.124
复制代码- $ sox -V justlisten-JL001-JL001+stereo-03_Puente-Celeste---Nama---Chiquita_DXD352KHz_2chDXD.wav -n stat
- sox: SoX v14.4.1
- Input File : 'justlisten-JL001-JL001+stereo-03_Puente-Celeste---Nama---Chiquita_DXD352KHz_2chDXD.wav'
- Channels : 2
- Duration : 00:04:37.57 = 97927984 samples ~ 20818 CDDA sectors
- File Size : 783M
- Bit Rate : 22.6M
- Sample Encoding: 32-bit Floating Point PCM
- Reverse Bits : no
- Channels : 2
- Samples read: 195855968
- Length (seconds): 277.573651
- Maximum amplitude: 0.258400
- Minimum amplitude: -0.226334
- Midline amplitude: 0.016033
- Mean norm: 0.023160
- Mean amplitude: -0.000025
- RMS amplitude: 0.029384
- Maximum delta: 0.291943
- Mean delta: 0.029345
- RMS delta: 0.037080
- Rough frequency: 70857
- Volume adjustment: 3.870
复制代码 |
